  • SN95 4.6L Mustang Tech
Somethings Wrong Please Help
  • Thread starter Thread starter 00GTpony
  • Start date Start date Mar 6, 2008
00GTpony
162
  • Mar 6, 2008
OK, so i feel like my car has been burning wayyy to much gas... also, when i put the heat on, it stinks of gas. Also occasionaly the exhaust will make a gargle sound, like a misfire for like 2 seconds... What wrong with my car!!!
Could it simply be just a faulty 02?... No codes, cause i have diablo shut it off...
Please Help
mrvax
Stay thirsty my friends
SN Moderator: Orlando, Fl.
Mar 7, 2008
  • Mar 7, 2008
Sounds like that tune is off. Is there anyway you can get an a/f reading? You should be about 13:1. Can you turn off the Diablo & return to stock settings?
W
WFOranger
28
  • Mar 7, 2008
Didnt think the diablo turned off the front O2 sensors just the rear. The rear meter how well your catalitic convertors are working while the front help control the fuel/air mixture. Even with the diablo the check engine light should come on if its something besides the rear O2s. I would convert it back to factory and see what it does. Kinda does sound like your tune is off.
00GTpony
162
  • Mar 7, 2008
no cause it was like that b4 i installed the tune to
Brute03
232
  • Mar 7, 2008
mine has been doing the same damn thing for a while and no one can figure it out (the shops around here suck) the exhuast note sounds kinda gargly (but not missing) at low revs - as if it's struggling to get going
SilverBullet00
1,150
Wichita, KS
Mar 7, 2008
  • Mar 7, 2008
do you guys have an exhaust leak? Do you have a midpipe that might sealed up correctly, or a manifold bolt loose?
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
'04 V6 running rich excessively on both banks
  • 04DSGVert
  • Oct 26, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Oct 27, 2025
04DSGVert
ECU help!
  • starkiller1134
  • Aug 16, 2025
SN95 4.6L Mustang Tech Aug 17, 2025
starkiller1134
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
