This isn't on a car, but could be.
I'm doing a engine swap on a lawn mower and I'm trying to remove a drive pulley off a shaft (bad engine) to put onto another shaft (good engine) so I can put it on the selfpropelled mower.
The set screw uses an 1/8" allen wrench and the pulley appears to be steel.
I've tried:
1. brute force
2. tightening before loosening
3. penetrating oil (PB blaster)
4. hitting the inside bottom of the set screw with a punch to loosen it up
5. heat (propane torch)
6. heat and brute force
7. heat and penetrating oil
8. heat and candle wax
9. heat and carb cleaner on the set screw (thermal shock)
10. different combinations of the above
At this point, my only option may be to drill it out, which I'd rather not do, just looking if there is an option I haven't yet thought of.
I've tried:
1. brute force
