Sound Clips
97WhiteStang
43
Vienna, VA
I'm not quite sure how i want to go with my exhaust ( direct fit or true duals). If i do go with the direct fit i want to get the flows...I would really like to go with the true duals but i dont know if i want to spend the money on the midpipe as well. For people with true duals do you notice a huge loss in low end power and what do u do when it comes time to get emissions done? Anyway getting to my point anybody have soundclips of their exhaust to help me make up my mind..
Thanks for your time,
Jake
SD ive checked out mustangexhaust.com my friend bought the mac direct fit but its sounds alot different in person than on the site...anybody here have the long tubes?
hey Dan, yeah thats real close we should meet up sometime...are you a member of NVMC?
are you suggesting that he gets straight pipes welded in to his exhaust? Wouldn't the result there be not much back pressure and loss of low end torque? Why dont you explain what you did sense you have done the duels on your V6 already. I was a bit confused myself when you said that too.
-Dan
you should have enough backpressure if you run strait pipes because of the 4 cats in the system like mine. but that is not what i meant. i meant trash the stock pipes and get some custom bent for each side with 2 cats per pipe and 2 mufflers of your choice. i got my car already like this, but right now i am running straights you could say since one muffler fell off and the other has no bottom. and take my advice, don't run your car with no mufflers, it sounds horrible.
