sound when my doors shut
  • Thread starter Thread starter jmd2914
  • Start date Start date Jul 5, 2009
J
jmd2914
937
Napa, California
Jul 5, 2009
  • Jul 5, 2009
when i shut the doors on my mustang they make a clanging sound ( thats the best way i can describe it). what im wondering is if any of the moving parts are worn/needing to be replaced. is there anything i can replace to get my doors to make that crisp thud sound that newer cars make when the doors close?
1991notchbackLX
1,483
47
48
New York
Jul 5, 2009
  • Jul 5, 2009
are the doors sagging? any body shop can adjust them if they aren't sitting in the frame correctly... but i'd just replace the hinges and bushings... late model restoration sells a kit, good luck
TenorPlayinGuy
1,208
Canyon Country, Ca
Jul 5, 2009
  • Jul 5, 2009
Yep usually the hinges go, and makes them sound awful as they smack the latch bolt off.
To make it sounds like a newer door, you gotta insulate and sound deaden, even then it wont even come close. Good luck though. I couldn't get it to stop making the oldschool twang as I shut it. Just a nice solid Latch of the bolt.
TechSteele
60
North Coast
Jul 5, 2009
  • Jul 5, 2009
If its clanging from a part thats come loose? Or just lack of thud sound?
You can do all the above and more,
New hinge Pins, grease everything, New moulding between door and body, sound deadening/insulation, new window wipes/moulding, window alignment bushings, or more.
It all depends how bad it is, and good you want it to be. (and what your willing to pay)
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Jul 6, 2009
  • Jul 6, 2009
It could be the window rattling around inside the door. Does it get worse when the wondows are down?
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Jul 6, 2009
  • Jul 6, 2009
What about the door striker bolt/bushing? Is that little plastic bushing that goes around the striker bolt cracked or missing? I've replaced those on a couple different Foxes and it made a HUGE difference in how solidly the door latches.
Also, give your door latches a good squirt with some WD-40 or something similar, just for good measure.
TechSteele
60
North Coast
Jul 6, 2009
  • Jul 6, 2009
The grey plastic bushings DO make a big difference. (Also fixed my alignment problem with the hatch)
Its hard to believe, but i will second that.
Took me a few days to find them on line and order them, THEN, found out that Murrays/Orileys right down the street carrys them in their "Help" parts section, DOH
QUICK91LX
968
New Jersey
Jul 7, 2009
  • Jul 7, 2009
I am gonna vote for loose window
1991notchbackLX
1,483
47
48
New York
Jul 8, 2009
  • Jul 8, 2009
I hate the way my passenger door closes, it's always bothered me since I got the car. The driver side closes lke a brand new car but the passenger side really sucks. I just read this and went outside to look at 3 am because I just had to know if both striker bushings were there. Needless to say the driver side has the bushing but the passenger side doesn't!! I just ordered one for $2.50 off CJ Ponyparts... if it fixes the problem it will be THE BEST $2.50 I've ever spent!! Thanks for the idea guys.
J
jmd2914
937
Napa, California
Jul 8, 2009
#10
  • Jul 8, 2009
  • #10
as far as i know both striker bushings are there i'll check when i get home in the morning. as far as the window it does get a bit worse when the windows arent all the way up
K
Door post and rust repair
  • Kleinjj27
  • Aug 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 8, 2026
Kleinjj27
K
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
R
85 T-Top doors hard to close... Just how it is?
  • rwordenjr
  • Dec 5, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 7, 2024
rwordenjr
R
