spark plug gap for headswapped cars
RysRed96GT said:
my car detonates slightly as it is now. platinum plugs gapped at .054 :(. maybe this would help me out some.
Hate to be a pain, but could you let us know how you like the coppers with the .40 gap. [ if it's still pinging a bit etc.]
Also, what coppers did you get, 22's ?
Well I'm running the autolite 764's at a .40 gap. Right now I think my exhaust leak is keeping me from getting a full feel down low, but up in the RPMs it runs just fine. Wish there hadn't been 2 weeks between the start and end of the swap so I can really compare it, however it is definately a LOT faster now.
you break the gasket when you reinstalled the h-pipe too?
tomustang said:
ryan how can you tell if it detonates slightly ?
it did it before i installed the midpipe, now i cant even hear **** anymore, just exhaust.
it did it under load sometimes at low rpms, sometimes high. though it seemed to be doing it more sincei removed my airbox. i might fabricate a heat shield for it :scratch:
If I drive along at 60 mph and slowly press on the gas, I can hear mine pinging.Not very loud, but it's audible. During the day, when the temp. is warmer, it pings considerably louder.
I wish there was somewhere to get 93 octane around here.
i'm going to bump this old thread again, as i realized i never responded as to whether i was still pinging with the smaller gap.
well, i forgot if it went away. it was over a year ago.
equally saddly, is i havent changed my plugs in that time.
im noticing some detonation under load at low rpms and sometimes at high rpms. i already changed out the fuel filter, no change. here are my suspicions...
1. Bad plugs - havent changed them in a year. they're autolite coppers.
2. Dirty injectors - I havent had a chance to pick up some seaform to run in the gas tank, but i have some STP that i'll try later.
3. Bad gas - i THINK it started since i filled up with Crown 93 octane that was discounted to midgrade prices (they do that every thursday).
My O2's are only about 5 months old. my MAF is clean. I get no check engine light at all.
Anyone have ideas?
I'm hoping its the spark plugs. Usually i hear some detonation during the hot summer months, but not when its cold. I'll finally let you all know in the next few days!
RysRed96GT said:
i heard in another thread that a smaller gap size, like .40ish, would make more power. supposably another guy in the thread confirmed it but i want to make sure. would i make more power with a smaller gap with my higher compression?
After my headswap, I had a fairly well known speed shop owner swear by gapping the plugs to .035. He claimed he tried multiple gaps and tested this at the track. So I ran with .035 (blower and nitrous setting.)
When I replaced the plugs I gapped them at about .053. HUGE difference. Yesterday I replaced the plugs again and gapped them to .055. HUGE difference.
My personal experience is that .035 is NO FREEGIN GOOD for a N/A Stang. When I gapped the plugs to the factory setting, the car ran MUCH better. I'm sticking with .053-.057.
If you're not sure, try .040 for a month. Pull the plugs and re-gap to .055. You will see a noticible drivability difference in favor of the larger gap.
Also, if you use the correct plug for your car and gap down to .040 or .035, I don't like the way the plug's electrode tip has to be bent to achieve that small gap.
BTW: I use NGK TR-55 plugs (copper for performance.)
well, i just cured the detonation problem! turns out it just had bad gas. i went to sunoco, put in some 93 and poured in a bottle of sea foam (just in case). all cured!
anyway, i still need to do my plugs. i actually recall now that when i gapped them smaller, it made a better difference. i remember it was smoother going up the rpm range under load. i recall being suprised when i drove it after being gapped smaller.
still, i will let you all know when i get to it.
