Spark plug gap on 351w
Xzkittle01
17
West Virginia
I have a 1994 v6 sn95 with gt swapped t5, driveshaft and rear diff. It has a 1994 351w in it with gt40p heads. It will be running a holley carb once the carb is rebuilt. I was curious what gap my spark plugs need to be at. I was reading forms and it say a 1994 351w has 0.042- 0.046 gap but I want to make sure with the modification that is done to it since the headers are in the way of the spark plugs and it's a pain in the butt to get to the 7th cylinder plug
  • Sponsors(?)
96pushrod
Advanced Member
May 15, 2018
816
496
73
28
Savannah
I have them at .046 so if that doesnt work I'll go up to 5.0 with some new plugs. Thanks for the help!
Honestly I’d just leave them where you have them. The only time it makes a difference is if you have a huge jump in gap, which doesn’t really apply here.
Thread starter Similar threads Forum Replies Date
T Spark plug gap Fox 5.0 Mustang Tech 3
H 65 289 spark plug gap/popping! 1965 - 1973 Classic Mustangs -General/Talk- 14
J Gt40P Heads Spark plug Gap. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
GTVin Engine 94 GT spark plug gap 1994 - 1995 Specific Tech 4
F spark plug gap? 1996 - 2004 SN95 Mustang -General/Talk- 2
BlakeusMaximus 2015 GT—What is the correct spark plug gap on these? 2015+ Specific Tech 9
S New Owner Spark Plug Gap Question 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
Robert Arco Spark Plug Gap - Not As Easy As You Think 2005 - 2009 Specific Tech 1
89gtsleeper Spark Plug Gap And Fuel Pressure Problems On 5.0 W/ Vortech Fox 5.0 Mustang Tech 4
D Aluminum Head Spark Plug Gap Needed Fox 5.0 Mustang Tech 3
Scrasauge Spark Plug Gap 1965 - 1973 Classic Mustangs -General/Talk- 1
John Dirks Jr Side Gap Spark Plugs 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
kcard Fox Spark Plug And Spark Plug Gap 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
RangerJoe Engine Spark Plug Gap Fox 5.0 Mustang Tech 5
Casey2552 Spark Plug Gap Question Fox 5.0 Mustang Tech 12
B help with spark plug gap Fox 5.0 Mustang Tech 1
musclemustangcb what spark plug and gap should i run with 17psi+water meth?????? SN95 4.6L Mustang Tech 4
0 2001 gt spark plug gap SN95 4.6L Mustang Tech 2
ViperPunk spark plug gap Fox 5.0 Mustang Tech 3
9 stock spark plug gap Fox 5.0 Mustang Tech 9
1 gt40 spark plug gap Fox 5.0 Mustang Tech 2
rispoli_23 suggested spark plug gap???? 1996 - 2004 SN95 Mustang -General/Talk- 7
andrewb_80 MSD Spark Plug Gap Fox 5.0 Mustang Tech 4
kreymis spark plug gap- 1994 - 1995 Specific Tech 3
poulrais Spark plug + gapping for AFR heads Fox 5.0 Mustang Tech 4
roworld spark plug gap Fox 5.0 Mustang Tech 17
Stang_1973 initial timing, spark plug gap, Classic Mustang Specific Tech 3
Jinx ? about spark plug gap SN95 4.6L Mustang Tech 7
98COBRA281 spark plug gap for nitrous? SN95 4.6L Mustang Tech 6
J ticking noise Gap closed in spark plug SN95 4.6L Mustang Tech 12
SC'D_96_COBRA Vortech 96 Cobra Spark Plug Type/Gap SN95 4.6L Mustang Tech 2
Cobra123089 Spark Plug Gap with cams SN95 4.6L Mustang Tech 15
M Spark plug gap for 1998 mustang GT SN95 4.6L Mustang Tech 1
Guero Spark gap and spark plug Fox 5.0 Mustang Tech 2
stang_racer69 92 Spark Plug Gap Fox 5.0 Mustang Tech 5
THELAW1 SPARK PLUG GAP FOR GT40 X303 HEADS Fox 5.0 Mustang Tech 1
L spark plug gap Fox 5.0 Mustang Tech 10
gcwh02 Spark plug gapping and size windsor jr head Fox 5.0 Mustang Tech 2
9 5.0 Timeing Spark Plug Gap Fox 5.0 Mustang Tech 2
L spark plug gap with super charger Fox 5.0 Mustang Tech 10
jcw88 spark plug gap 347? Fox 5.0 Mustang Tech 12
donkey_punch question about spark plug gap? 1994 - 1995 Specific Tech 9
Luis911 E7TE porting, best Timing and gap spark plug? Fox 5.0 Mustang Tech 3
navarro98gt Spark Plugs/gap SN95 4.6L Mustang Tech 26
The Green GT Spark plug gap... 1994 - 1995 Specific Tech 16
1 spark plug gapping on trick flow heads Fox 5.0 Mustang Tech 8
98BLKGT Spark plug gap w/ trickflow heads. Fox 5.0 Mustang Tech 4
N Spark Plug Gap... head or block? Classic Mustang Specific Tech 6
Funanin spark plug gap with nitrous? Fox 5.0 Mustang Tech 6
ryan218 spark plug gap 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 21
