Spark plug gap...
The guy at AutoZone went out of his way to write on my sparkplug box that I should gap the plugs at 0.54".
A half inch is a bit wide if you ask me but what do I know. :rlaugh:
I gap mine around 0.054".
Wes
Come On Now Wes :D
A teeny tiny decimal point or a little insignificant Zero :shrug:
What possible difference could one or the other make :scratch:
Grady
good luck finding one
No Luck Needed:nono:
All you gotta do is ;)
Go to a supply house that specializes in Import Parts :nice:
They keep em in the special section along with ........
Muffler Bearings
Blinker Fluid
and
Replacement Radiators for Corvairs ( JT will understand) :)
and
The most important tool needed to work on Imports :Word:
Metric Crescent Wrenches :D
Grady
According to our hoods (if any of you even have the stock hood anymore, lol) 0.054" I believe.
This is correct.
While were on this subject I have a question. What are the affects of changing the gap. On a mostly stock 5.0, what would gaping at .045 do, or .035 for that matter. I know most use a smaller gap when using nitrous or blown applications, but how will it affect performance on an N/A car? Can it help reduce detonation. I could use that. lol. Thanks.
- Justin
They are hard to find, because they don't exist, right? Diesels rely on high fuel pressure and high compression to ignite the air/fuel mix, rather than a spark.
Correct. It compresses it so much, the atoms in the fuel air mixture get super hot from rubbing each other and explode. (Atleast that how it was explained to me)
