Spark Plugs
JTGrant
775
GA
Correct me if I am wrong, but the plugs in our cars are plat. and have that wierd ground strap. I would like to get a copper electrode and have a normal plug so I can change the gap. I hate plat plugs yes, they last longer but you get a better burn with copper plugs. I do not mind changing plugs every 10k. What other plugs(non-plat) run well in our engines? I was thinking of starting at .060 gap. Suggestions?
Plugs
I wouldn't try using different plugs than what came in the car. These new plugs were designed for our new 3 valve engines. I haven't heard anywhere that you can use the old design plugs. I don't think there is anything wrong with platinum plugs, I think the stories about copper running better than platinum is just an old wives tale. A lot of high end cars come with platinum plugs. Unless you are running something really exotic like a S/C or nitrous, I believe the OE plugs are just fine. Just my $.02 worth.
Have you seen what the plugs look like??? You can' t set the gap on them. Better burn with coppper? Definetly old wives tale. In s/c there ar still platnum but a colder plug not copper. i just insatlled a s/c on mine. Leave the orignal in there they are perfect fro the application.
no not an old wives tale, when a copper plug lights it actually breaks off small particles from the electrode, thus giving you a better burn.
Plugs
Do you realize that a so called "copper" plug has iron electrodes? Copper electrodes wouldn't last 50 miles. The only copper is the core of the plug which never sees the combustion chamber. The people that down platinum plugs are a left over from the old 88 cent Champion plug days, they believe anything new must be bad for performance and that's just not true. These are the same people that say they'd rather have a "good old 4-barrel" instead of that new fangled fuel injection. Ford has some very high paid engineers designing these modern engines and I believe what they say.
did I say that the electrode was copper NO I DID NOT
JTGrant said:
Does anyone know what is the best plug to use in our engines? I know there is several companies that make this type of plug. Thanks
Please post some sources and PN's, I can only find the Motorcraft and Autolite #s. (Same folks)
Not that they suck, but I've always liked NGK.
Thanks.
yes you can gap these plugs ... vortech sells a gapping tool specifically for them costs about 40 bucks
No gapping is needed? So I can just install new plugs right out of the package? If so, why is there a gapping tool (suposedly), as listed above?
Last question, how often does everyone change their plugs?
