Sparkplugs Question!!!!
rflow50
172
TX
I am installing a Supercharger this weekend and I know that when you put a Blower you need to put different spark plugs. My question is which one to go with. I have trick flow twh, and the spark pulgs that i am using now are NGK.
I would like to know if i should stay with the NGK's or change to another brand.
I would also like to know the part number in case is different and what gap should i calibrate them since I'm also using an MSD 6AL. thanks
NGK makes a good plug, you want to go one heat range lower then what you currently have, and gap them down to .035"
I like Autolite plugs also, stock is a #24 with a blower a #23 works good.
