Speaker rating question
Right now I have an Alpine 9856 head unit (50Wx4 max, 18Wx4 RMS) running with (4) Pioneer 6"x8" 3-ways (220W max, 50W RMS). I am more concerned with better sound as opposed to louder sound. Would it be better (clearer) to get a 50Wx4 RMS amp to drive these speakers? Or better to downgrade to the Pioneer 6"x8" 2-ways (160W max, 30W RMS) and bring the speaker rating closer to the HU rating? I have another car with the same Alpine and 2-ways, but it is a different car, different insulation, etc. so I can't make any comparisons based upon that.
Since your speaker are already overkill for use without an amp, you need to get a 4 channel.. In general, if you wanted to be cheaper and run off deck power, get a speaker which is more efficient meaning lower power numbers... This is a ridiculously common mistake... People figure the higher the power rating on a speaker, the better it is.. FALSE!!!!! I run memphis m class coaxials in my Explorer and they outperform many amped systems because they are so efficient.. Carbon fiber cones, rated at 50 rms, 100 peak.. They even have very significant midbass..
So if i swap to lower rated speakers (30W RMS instead of 50W) I should be okay? I originally went with the 3-ways because they are better constructed than the 2-ways, and less expensive than the 4-ways. But now I realize I should use the 2-ways. How will they sound different? Also, therere are factory tweeters in the front doors, and these are wired in parallel with the front (door) speakers. The head unit seems to operate fine this way, without overheating or shutting off.
You have to remember a few things:
1. Even though the headunits amp gives a rating, that rating usually has a high level of distortion.
2. I'm sure you've seen a "true" 50Wx4 amplifier. Remember how large of a chassis it took to fit the components into it? Now imagine the size of the amp in the Alpine deck and you can understand why they aren't the same. There's now way they can cram quality components into that small a space.
IMO, your decision to have "better" sound is vague and you need to ask yourself a few questions...
1. Do you want to be able to play it louder and still have it sound clean?
2. Do you mean better in terms of frequency response of your system?
The external amp will give you the ability to play the system louder without distortion, meaning "less" chance of damage to your speakers. However, if you want better frequency response, i.e. bass, your only option is to add some type of subwoofer(s) AND an amp for your 4 other speakers. No matter what you do, your 6x8's won't produce any low frequency notes. Turning up the bass on the deck will only add distortion, meaning the speakers cones are moving more than they're intended to do, and eventually you'll throw a voicecoil and have a blown speaker.
I can go on and on, but hopefully you get the idea. Hope that helped.
