Drivetrain Spec stage 1 horrible chatter
keel
245
100
53
Seattle, Wa
Just installed a spec stage 1 and every time I start from a stop the whole car shudders horribly, no matter what I do. Shifts fine otherwise. So far I have put about 15 miles on the clutch.
Input shaft bearings, pilot bearing, the retainer the throw out bearing rides on, the throw out bearing itself and the flywheel surface. Any one or combination of these can cause this.
Did you do the work and what didn't you replace?
I replaced the input shaft bearing retainer with a steel one, I replaced the pilot bearing, the throwout bearing, and had the flywheel resurfaced. I did not replace the input shaft bearing.
I still would suspect the flywheel or pressure plate. And please check the cable. After breaking one, I include that when replacing the clutch.
Greasy fingerprints are the only other thing I have not seen mentioned that is even close to a common cause I can think of.
Reactions: General karthief
