Special driveshaft for Tremec tko?
93steeda said:
I dont know about a special driveshaft, you do have to change the yoke for the tko, but I used my stock driveshaft and just had it balanced and new u-joints put in it.
SO i could use my stock driveshaft, wht did it cost you to get it balanced...so all I need is a new yoke then?
no they arent. But if you are going to do all the work of replacing the u joints and getting it balanced, youd be better off buying the FMS aluminum driveshaft. If your on a budget i can understand. But if you have the money put the FMS in. Just my opinion though.
fms's are not that expensive, so I might as well look into one, thanx, someone just told me to get the 3550 instead cause with the tko you need a speical shaft, but since all you need is that part, then im all good
