I have an 87 gt that I just put an edelbrock performer rpm2 manifold on. Now the car idles at 3500 rpm. Previous to this I put 1 3/4 long tubes, off road x-pipe and two chambers, 70mm throttle body and egr, 255 in tank pump, CAI, full tune up with MSD coil, wires, cap and rotor, underdrive pulleys, a/c and smog pump eliminated and car ran perfect. I have replaced vacuum lines and checked vacuum at 19psi, fuel pressure and timing are perfect, new map sensor, iac, tps, pcv, thermostat, and o2 sensors. No missfire, plugs are good.
I pulled codes and got a 44,94 which are for the thermactor system, but believe these to be because of smog system eliminated. Also got a code 15 for ecm rom fault. already have a new ecm on the way, just want to know if anyone has any other ideas if this doesnt fix(other than mass air conversion)
Thanks much
Thanks much
