  • 1994 - 1995 Specific Tech
Speedcal Install on Automatic
  • Thread starter Thread starter 95BlackTan50
  • Start date Start date Dec 29, 2004
95BlackTan50
116
  • Dec 29, 2004
I was searching the posts but couldn't find a post on how to install the Speedcal on an automatic. The problem that I am having is how to get around the shifter to feed the wires down to the tranny. I unscrewed four bolts that hold the shifter down, but it looks like I would pinch the wires if I pushed them through and tightened the screws back down. Any thoughts?
95BlackTan50
116
  • Dec 30, 2004
Anyone?
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Dec 30, 2004
  • Dec 30, 2004
Maybe this will help
http://www.superstallions.com/tech/elect/speedcal/speedcal.html
95BlackTan50
116
  • Dec 30, 2004
Thanks Wytstang. That article talks about the manual shifter. The automatic shifter seems to have a tight seal all the way around it and it's secured by 4 bolts. There doesn't seem to be a path from the inside of the car to the tranny below without cutting metal.
I saw a post somewhere that talks about installation on an automatic, but I can't seem to find it again.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Dec 30, 2004
  • Dec 30, 2004
Not to many people here use the speedcal your best bet it to go to www.dallasmustang.com (they make the speedcal) and join the tech forums.
1hot5.0
1,615
Surprise, Arizona
Dec 30, 2004
  • Dec 30, 2004
Minus the stupid part.
95BlackTan50
116
  • Dec 30, 2004
Thanks for the info. I posted the question to DM but haven't heard anything yet.
I did find the post that I was looking for on the corral. The response was:
"The hardest part of the installation is feeding the wires/connector through the floor! I routed my SpeedCal wiring through the front of the hole."
I'm not sure what that means.
I just bought some small grommets at Autozone and I think I'll drill a small hole, add the grommet, feed the wires, then fill the hole with RTV. That seems to be the cleanest way that will prevent the wires from being crushed or chaffed.
Thanks again for the help.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Dec 30, 2004
  • Dec 30, 2004
Put some primer after you drill the hole to avoid rust from forming just in case.
95BlackTan50
116
  • Dec 31, 2004
I got the SpeedCal installed last night. I ended up drilling a 3/8 inch hole as far forward as I could on the drivers side of the shifter. The 3/8 hole was a perfect size since the plastic protective sleeving over the wires just barely fit through, and it was tight enough to keep the wires from moving around below. If you drill the hole too far aft, it may interfere with the linkage. Not that I drilled one there by accident. I have a picture, but can't figure out how to post it. The only problem that I had was that I needed to remove the connector from the grey and white wires to get it through the hole. For that I needed to pull out the red lock, release the wires and pull. The only other thing that I did differently was to tap into the switch 12V wire (purple and pink?) that goes to the convertable control. That way, there is not power to it all the time. The wire is there for the coupes as well, it's just not used.
Anyway, after I got it installed and set the switches, I took it for a test drive. Using highway markers, I measured 14.7 miles for a 15 mile run. After readjusting the switches for a 2% correction, the readings were right on. There was less than a tenth of a mile difference after 18 miles. That's less than a half a percent error according to the odometer and the mile markers and that's close enough for me.
I need to get back in there for the primer since I just now saw your last post WYTSTANG.
Thanks for your help and Happy New Year.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Dec 31, 2004
#10
  • Dec 31, 2004
  • #10
Anytime and have a safe night
Suspension 87 steering wheel slightly wobbles after new Rag joint install
  • R82148V
  • Jun 16, 2025
Fox 5.0 Mustang Tech Jun 24, 2025
R82148V
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
  • dan50
  • Jul 18, 2026
dan50
T
Convertible A-pillar weatherstrip issues
  • thiefofcheese
  • Oct 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 20, 2025
AeroCoupe
