Screamin' Demon said:
Where do you install the speedcal for a 97 GT auto. I need to know for when the gears arrive so if anyone knows say so please. Is it something the installer boys do? Wheres the best place to get your gears istalled, thanks!
Get the SpeedCal bro. I have a 98GT AT that's the only way to get an ACCURATE reading on your speedo. Without the SpeedCal you'll be anywhere from 6 to 18 miles off (gap progresses as your speed does). DO NOT get the little white plastic piece of crap gear. It will shred in less than a year.
The install for the Speed cal is pretty easy. Follow the directions it comes with, couldn't be any easier. Here are some helpful tips.
You don't have to pull your center console all the way out. Take out the couple screws by the stereo, I think under the cup holder and a few inside the center compartment. After you pull the screws out and unsnap the four snap deals by the shifter. Be careful, I broke one
Once you got that stuff out of the way pull it back as far as you can. Unbolt the four bolts on the MAIN steel plate on the bottom. There is no easier way to do it, trust me I tried. Whatever you do, DO NOT try and take the shifter handle off. I tried and got my tranny locked out of 1st and Park. Don't ask how.....
Once you take out the bolts that secure the shifter in place you can move the entire assembly far enough to the right side to see the ground. I cut a small notch in the body below the plate so it wouldn't crush the wires.
The rest is as the directions instruct. The SpeedCal itself fits snuggly to the left in front of the shifter. I used some velcro to secure it in place.
This is my story, do what you will with it.
Good Luck
