  • SN95 4.6L Mustang Tech
Speedcal?
  • Thread starter Thread starter Mr GT 02
  • Start date Start date Oct 11, 2004
Mr GT 02
548
Peabody, MA
Oct 11, 2004
  • Oct 11, 2004
I plan on getting 3.73 gears in the future. It is said that u must get a speedcal in order to re calibrate your speedo.
How would the process work? is a speedcal suttin u plug into the computer?
What is the process....is it a simple thing to do yourself?
w00t
334
Arlington TX
Oct 11, 2004
  • Oct 11, 2004
After reading the post regarding the Diablosport chip. I would pay the extra bucks and purchase the chip. You can make the gear change as well as many others from the Diablosport chip.
http://forums.stangnet.com/showthread.php?t=508583&goto=newpost
SlapStick1999GT
florida
Oct 11, 2004
  • Oct 11, 2004
If you buy a hypertech programmer you can reprogram the speedo and as well set shift points, tire sizes, set rev limit, set firmness of each shift and much more. (do your research)
M
moreause
74
  • Oct 11, 2004
In short the speed cal intercept the signal comming from the transmission and send it back to the computer with the right ratio. From what i have seen the put it under the shifter panel.
For my i bought a diablo predator. The only down side is you can't only change the ratio (if you want to have a clear conscience ). But you can change the ratio when you put the tune in.
jrc_03_gt
786
  • Oct 11, 2004
I have a speedcal and it is a little box that has dipswitches in it. You mount it under the shifter panel. You can adjust the speedcal to different tire sizes too. It works for all gear ratio's too. Look at the dallas mustang web site or better yet call them .
XTONKAX
619
UT
Oct 11, 2004
  • Oct 11, 2004
Auto or 5 speed? Or do I just not see it?
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
  • dan50
  • Jul 18, 2026
dan50
Progress Thread 93 LX father son project
  • ZAM93LX
  • Oct 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 3, 2025
Scrapla347
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
