I don't think my issue is so much the cable as the gauge cluster, itself, but I've got the bouncing speedo, too. It usually gets crazy about acting up when it's colder outside (anything below 60* and it gets really weird-acting).
Pull your VSS (at the tranny end of the cable) and see if your speedo gear is chewed up. Mine's still good, hence my suspicions about it being the gauge cluster (260k+ miles and counting!).
The tranny fluid leak is probably due to the O-ring around the VSS (vehicle speed sensor) that plugs into the tranny. You can either try going the cheap but PITA route of finding an exact-sized replacement O-ring - everything I found was either a hair too big to fit in, or too small to do any good - or just buy a new VSS. (I ended up taking the latter route, myself.)
FWIW, my Pioneer speedo cable (from Autozone) has been working just fine for about a year and a half. Can't say the same for Pioneer's clutch cable quality, however - that turd snapped on me after about 9 months.
