speedo gear for 3.73 and T5?
50resto's speedo gear chart is a bit off from the others I've seen. I'd suggest checking Steeda's site, as its list appears to be a bit more specific regarding years and types of transmissions.
Bear in mind that with a 23-tooth speedo, you're going to want to change out the tailshaft speedo gear as well to get anything close to a proper reading, unless yours already has the proper tooth-count tailshaft gear. Not an easy task. Also, I've heard a lot that the 23-tooth speedo gears don't last all that long because it's actually not even a Ford speedo gear - it's out of a Jeep, or something odd like that. :scratch:
to much work if it eats it ill put another one in it and just guess my speed like im doing know. lol. when it says im going 80 im realy going 65. when it says 65 im really going 55. drove the truck with this one side by side that way i had a gauge to know what im doing.
That's pretty much what I'm doing with my '89. I stuck in a 21-tooth gear because I heard about the 23-tooth gears getting chewed up, and I've figured most of my equivalent speeds out either by adding 5, 10, or 15 MPH on top of the speed (30 = 25, 55 = 45, 80 = 65 or 70) or by going by gear and RPM (2,500 RPM = about 65 MPH). I'd like to have it read 100% correct someday, but it's not really high on my list of priorities. :shrug:
That chart's kinda confusing for a simpleton like me. Doesn't say much about the AOD cars as far as whether they have a 6, 7, or 8-tooth tailshaft speedo gear - only makes mention of the T-5 cars. Did all AOD's from '83-'93 get the 6-tooth speedo? Or did they switch to a 7-tooth in '90, or what? :scratch:
