Speedo gear for T5Z and 3:27=21 Tooth???
bcmbcmbcm
Jan 29, 2003
455
Hey folks,
the chart from 50 resto breaks down T5s into 83-89 and 90-93. Do I use the 90-93 chart for a FMS T5Z? if so am I right that I need a 21 tooth for 3:27?
Thanks in advance,
Brett
Ring & Pinion Speedo Gear Part Number
1983-89 Mustang Manual 5-Speed
3.08 18 Tooth LRS-17271H
3.27 19 Tooth LRS-17271A
3.55 20 Tooth LRS-17271B
3.73 21 Tooth LRS-17271C-K
4.10 23 Tooth LRS-17271D-K
1990-93 Mustang Manual 5-Speed
3.08 20 Tooth LRS-17271B
3.27 21 Tooth LRS-17271C-K
3.55 23 Tooth LRS-17271D-K
I beleive the t-5z uses a yellow 7-tooth drive gear like the 83-89 t-5's
Do you have the trans? Peek inside where the speedo gear goes. The drive gear will be color coded.
Black = 6 tooth
Yellow = 7 tooth
Green = 8 tooth
If it's yellow you need a 19 tooth with 3.27's, if it's green you need a 21 tooth
