Speedo Gear?
  • Thread starter Thread starter 92Frankenstein
  • Start date Start date Jul 7, 2004
1 of 2 Next Last
9
92Frankenstein
223
Minnesota
Jul 7, 2004
  • Jul 7, 2004
I have a 75 C4 that I put inside my 92 vert with a 7.5 rearend with 3.73 gears, stock 14" tire.
Which gear do I need?
SLiM JiM 156
1,024
Rohnert Park, CA
Jul 7, 2004
  • Jul 7, 2004
*edit* what is this tranny out of?
9
92Frankenstein
223
Minnesota
Jul 7, 2004
  • Jul 7, 2004
A 75 Maverick.
Thanks
9
92Frankenstein
223
Minnesota
Jul 8, 2004
  • Jul 8, 2004
Bump..
Still need help really bad.
Thank you.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 8, 2004
  • Jul 8, 2004
Check to see if there is a speedometer shop in your area. If there is, ask about the Stewart-Warner speedometer gearbox. I believe it is either a 777 Series Drive Joint Kits and Parts or 666 Series Drive Joint Kits and Parts. It is a small gear box that fits between the speedo pickup gear on the transmission and the speedometer. It has quick change gears that allow you to choose almost any tire size and rear end gear ratio you want. This will allow you to get the accuracy with within 1%-3%. The drawback is that it isn't cheap.
9
92Frankenstein
223
Minnesota
Jul 8, 2004
  • Jul 8, 2004
So I cant get a speedo gear? I am not looking for 100% accuracy, just close, maybe 3-5 MPH off, Could I just go ask for a speedo gear for a 75 maverick with 3.73's and a C4? Or is it not that easy?
The car is about done and this is the only part I have, and I am kinda low on cash, I was hoping I would be able to pick up a speedo gear at ford for like 20 bucks and be close...
9
92Frankenstein
223
Minnesota
Jul 10, 2004
  • Jul 10, 2004
Went to ford today, and they do not have a 23 tooth speedo gear like some recommended..
Still need help.
5.0guy
320
MI
Jul 10, 2004
  • Jul 10, 2004
I believe the 23 tooth is a jeep part
9
92Frankenstein
223
Minnesota
Jul 10, 2004
  • Jul 10, 2004
Do you know what the part number is? Maybe I will just have to go to jeep and pick one up...
9
92Frankenstein
223
Minnesota
Jul 10, 2004
#10
  • Jul 10, 2004
  • #10
Automatic Transmissions with 7 Tooth Drive Gear
1983-1989 Automatic Transmissions
Item Number
Description
D0OZ-17271-B
3.73 Gear Ratio / Purple 21 Speedo Gear
Will this work in my C4?
Thanks.
9
92Frankenstein
223
Minnesota
Jul 10, 2004
#11
  • Jul 10, 2004
  • #11
TTT
9
92Frankenstein
223
Minnesota
Jul 10, 2004
#12
  • Jul 10, 2004
  • #12
COME ON!!! I barely ever ask for help and i run into a major problem and no 2 people can help me??
Someone has to be running a C4 and 3.73's????
WHAT DO I DO???
I DONT HAVE TONS OF MONEY!!
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jul 10, 2004
#13
  • Jul 10, 2004
  • #13
You have tons of money - put a T-5 in it, and then I can help!
I'm following along - my problem is that I'm not familiar enough with the C4's to know what their drive gears are like - and if they even mesh up with the cable out of the STang. Does it have the speedo hooked up and it's just not accurate? Or is it not even hooked up? Another variable is your tire height. How tall is the tire? Or what's the size of it - we can calculate height from that. The '92 Vert came stock with 14" tires? Tire height will impact speedo accuracy too. The challenge is that all the data out there is for T-5's and AOD's with 16" tires (for the most part). So every piece of yours is different. You may ultimately have to follow jrichker's advice to get it to work together.
9
92Frankenstein
223
Minnesota
Jul 10, 2004
#14
  • Jul 10, 2004
  • #14
Well I was hoping someone could calculate a speedo gear tooth number for me.
Yes, it comes with 14 inch tires...
Ford told me they only went up to 21, will that be accurate with 14's, or is it going to be more off?
Thanks for the help. If i could find something that would be no more than about 5 off I would adjust to it, because it was 3 off before.
Just too risky to drive without a speedo now adays....
9
92Frankenstein
223
Minnesota
Jul 10, 2004
#15
  • Jul 10, 2004
  • #15
the tire is a 205-65-14 I beleive???
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jul 10, 2004
#16
  • Jul 10, 2004
  • #16
You didn't answer some questions - is it already hooked up and inaccurate, or is it not hooked up at all? Do you know if the Stang's speedo cable/gear is compatible with the C4? Those tires are about 24.4" tall (if you're correct about the size) - compared with about 25.7" tall for most of the HO Stangs out there. That makes your 3.73 gears about like a 3.89 gear in a Stang with stock 16" tires. But here's the challenge - the C4, I believe, is a 3 speed tranny with a 1:1 final drive (boy is that thing gonna be a revver on the highway!!!). The AOD's and T-5's have a top gear ratio of about .68 or .63:1. So your top gear is about the same ratio as if you drove along in an AOD in 3rd gear, or a T-5 in 4th gear. Consequently, finding the right gears to make an accurate speedo is a tough task. It will likely require changing the drive gear inside the C4 - which is usually a major pain (on the T-5 it is) -- that's why I said following jrichker's advice about getting a speedo box to correct the error may be the best way to go.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jul 10, 2004
#17
  • Jul 10, 2004
  • #17
Do you want the speedo to work, or do you just need to know how fast you're going? If it's the latter - you provide me with the size tires on the rear of the car, the final drive ratio, the final drive ratio of top gear in the tranny - and I can run some calcs for you that will tell you how fast you're going at certain rpm.
9
92Frankenstein
223
Minnesota
Jul 10, 2004
#18
  • Jul 10, 2004
  • #18
No, I do not have a speedo gear, and I was TOLD that the cable works with the c4.
So do you think my best bet is to get the 21 tooth gear until I change rear ends and gears and what not?
I am just looking for the closest speedo gear as of now, and where to get it.
Is the best I can do the 21 tooth??? and about how off do you think it will be?
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jul 10, 2004
#19
  • Jul 10, 2004
  • #19
Even a 23 tooth will be WAY off because of the lack of OD on that tranny. It seems to me that you don't understand the speedo implications of what you've got in the combo. If you had an AOD, a 23 tooth would get you close, but because of the difference in top gear ratio (1:1 on your tranny; .68:1 on an AOD) - you'd still be over 30% off. Are you contemplating another rear end/gear change? I'd get that and whatever wheels and tires you're ultimately gonna have on the car before I tried solving the speedo. I'd also get underneath and see if the Mustang speedo cable will even hook up to the C4 without some sort of adapter. You've got lots more homework to do before you can begin to figure out what gears are needed to make things accurate. And even then, I suspect jrichker's solution is what will be needed when all is said and done.
9
92Frankenstein
223
Minnesota
Jul 10, 2004
#20
  • Jul 10, 2004
  • #20
i guess I am a little confused.
They put the C4 in 79-82/3 mustangs correct? Dont you think i could get a speedo gear for like, 3.55's and be close, or will it still be way off due to wheels and what not.
Sorry for not being in the know.
Thanks.
1 of 2 Next Last
D
Speedo and tach dead
  • Davinrobinson1
  • Jul 19, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jul 26, 2026
fasterthangas
F
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
K
Drivetrain '87 5.0 Installing New Ring Gear and Pinion - Pattern Questions
  • karhoot
  • Apr 23, 2026
Fox 5.0 Mustang Tech May 9, 2026
Mindseye007
Drivetrain 5th Gear Ratio
  • PonyGTrider
  • Dec 8, 2025
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
