Speedo Gear
  • Thread starter Thread starter Turkey Sammich
  • Start date Start date May 18, 2007
1 of 2 Next Last
Turkey Sammich
I can't fap normal. I cracked a rib, then my ankle
Jul 12, 2006
154
May 18, 2007
  • May 18, 2007
My T5 recently went in without the speedo gear. Why it was removed is beyond me
How difficult would it be to put it back in, Estimate of start to finish, and where to install the gear at?
CRASH7772
401
NH
May 18, 2007
  • May 18, 2007
Takes about 5-10 mins to install.
Here is some info to help decide which gear to get...
Figuring gear ratio with different size tires.
Divide the old tire diameter by the new tire diameter and then multiply by the current ratio. So a stock 87 tire is 225/60/15 or 25.63 diameter and say we put a 255/60/15 or 27.04 on.So 25.63 divided by 27.04=.9461 then multiply by the stock 2.73 gear and get 2.588 which is definitley not a drag gear.
This is a good site for comparing tire sizes http://www.1010tires.com/TireSizeCalculator.asp .
Manual Transmissions with 7 Tooth Drive Gear
# 1983-1989 T-5 OEM
# Pre 1993 T-5 Aftermarket
# 1996-1998 Cobra T-45 OEM
# All Tremec Transmissions
2.73 Gear Ratio / Maroon 16 Speedo Gear
3.08 Gear Ratio / Yellow 18 Speedo Gear
3.27 Gear Ratio / Pink 19 Speedo Gear
3.55 Gear Ratio / Black 20 Speedo Gear
3.73 Gear Ratio / Red 21 Speedo Gear
4.10 Gear Ratio / White 23 Speedo Gear
Manual Transmissions with 8 Tooth Drive Gear
# 1990-1995 T-5 OEM
# 1996-1998 T-45 OEM Except Cobra
2.73 Gear Ratio / Yellow 18 Speedo Gear
3.08 Gear Ratio / Black 20 Speedo Gear
3.27 Gear Ratio / Red 21 Speedo Gear
3.55 Gear Ratio / White 23 Speedo Gear
3.73 Gear Ratio / White 23 Speedo Gear
Automatic Transmissions with 7 Tooth Drive Gear
# 1983-1989 Automatic Transmissions
2.73 Gear Ratio / Blue 16 Speedo Gear
3.08 Gear Ratio / Gray 18 Speedo Gear
3.27 Gear Ratio / Tan 19 Speedo Gear
3.55 Gear Ratio / Orange 20 Speedo Gear
3.73 Gear Ratio / Purple 21 Speedo Gear
Automatic Transmissions with 8 Tooth Drive Gear
# 1990-1998 Automatic Transmissions
2.73 Gear Ratio / Gray 18 Speedo Gear
3.08 Gear Ratio / Orange 20 Speedo Gear
3.27 Gear Ratio / Purple 21 Speedo Gear
Turkey Sammich
Jul 12, 2006
154
May 18, 2007
  • May 18, 2007
Thanks
Will I need to pull the T5 back out of my car?
CRASH7772
401
NH
May 18, 2007
  • May 18, 2007
Turkey Sammich said:
Thanks
You might need to jack it up or put it on ramps. Right about where you drivers side seat is (under the car) you'll find the speedo cable. There should be a screw/bolt holding that into the trans. Take that out and the cable should pull right out (assuming it's there to begin with), the gear will slide onto the end and there is a clip to hold it on to the cable. Just reverse for the install.
bobbyd
312
San Antonio/Los Angeles
May 19, 2007
  • May 19, 2007
will it be the same for a AOD? same location and everything?
CRASH7772
401
NH
May 20, 2007
  • May 20, 2007
You know I have actually never ever seen an auto up close on a 5.0 but I would imagine that it would be very similar.
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,121
224
Massachusetts
May 20, 2007
  • May 20, 2007
Which gear are you talking about??
The drive gear that mounts on the output shaft of the t-5, or the driven gear that goes on the speedo cable??
Turkey Sammich
Jul 12, 2006
154
May 20, 2007
  • May 20, 2007
The drive gear that mounts on the output shaft of the t-5.
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,121
224
Massachusetts
May 20, 2007
  • May 20, 2007
You can install it with the trans still in the car, but it will be tough. You need to take the tailhousing out and if you do it in the car you will need 2 people.
Easier to pull the trans out and do it on the bench
Turkey Sammich
Jul 12, 2006
154
May 20, 2007
#10
  • May 20, 2007
  • #10
That's what I was afraid of. Thanks for the advised
Chuckman
GTFO you fat, heavy bastard
1,604
1,002
173
st. louis, mo
May 20, 2007
#11
  • May 20, 2007
  • #11
i did it before i put the trans in my car, very easy, should take about 10-15mins. pop off the shifter, pound out the rollpin, unbolt the tail, slide it off, gear is held on with a clip, then put it together like you took it apart. getting that little spring on the detent ball was the hardest thing for didnt, bastard didnt want to stay still long enough to get it engaged right.
CRASH7772
401
NH
May 25, 2007
#12
  • May 25, 2007
  • #12
My bad for not asking that. I couldn't imagine why anybody would pull that out????
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
May 25, 2007
#13
  • May 25, 2007
  • #13
Kinda weird that the 3.55, 3.73, and 4.10's all take the same 23-tooth speedo gear for the 90+ T-5's. I'm guessing the 3.73's would be the only halfway-accurate gear ratio with that speedo gear, then...?
Also got me to wondering how I'd know if my T-5 was a 90+ unit or a pre-90. I stuck a 21-tooth gear in there a couple years ago (closest I could get to 4.10's at the time) because I figured mine was an 89 or older, and I didn't want to deal with changing out the other internal gear ... but now I'm kinda wondering if maybe I do, in fact, have a 90+ T-5. Hmmm...
90_Red_LX
668
Asheboro, NC
May 25, 2007
#14
  • May 25, 2007
  • #14
For 3.55s it is dead accurate. 3.73s its around 5-10mph off. 4.10s is way bad, just they say use the 23 toother for the 3.73s and 4.10s because it's the highest tooth count offered. This applies for the 90+ t5s. Pre 90 the 23 toother is accurate up to 3.73s, and the 4.10s are a few mph off.
JustA5.0
148
Toronto, ON
May 25, 2007
#15
  • May 25, 2007
  • #15
You could purchase the 23 tooth white gear and see if it's accurate (= 89 older) or still off (= 90+). Also, not sure what tire size you have, but it will play a small factor in accuracy.
JustA5.0
148
Toronto, ON
May 25, 2007
#16
  • May 25, 2007
  • #16
I'm fairly certain the 7tooth drive gear needs a red 21 for the 3.73s and a white 23 for 4.10 gear ratio. So a 23 tooth speedo gear should be quite accurate on the pre-90 OEM T-5.
90_Red_LX
668
Asheboro, NC
May 25, 2007
#17
  • May 25, 2007
  • #17
Hmm. You may be right on that one. I know 90 and up though the 23 tooth is not accurate for 3.73 gears though for a fact.
JustA5.0
148
Toronto, ON
May 25, 2007
#18
  • May 25, 2007
  • #18
^^ Correct, due to the 8tooth drive gear in them
Darkwriter77
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
May 25, 2007
#19
  • May 25, 2007
  • #19
I was told that you had to swap out the internal gear to use the 23-tooth speedo gear, however, because a 7-tooth internal gear would just eat the thing up...?
Hell, just for giggles, I may as well put the thing up in the air and verify for certain that it's got 4.10's, anyhow. It certainly pulls, drives, and cruises with the higher RPM's in a way consistent with 4.10's, which is what the prior owner claimed that had been installed. The speedo still reads 10 to 15 mph high at 65 mph, though, with the 21-tooth gear, so either I've got a 90+ T-5 with 3.73's (or 4.10's?), or I've got a pre-90 with 4.10's and I'm one step down in gear teeth count.
As far as higher-count speedo gears ... weren't some guys running a speedo gear out of a Jeep for 4.10's? Or was that the same white 23-tooth gear already recommended?
Mr Grim
58
#20
  • May 25, 2007
  • #20
I have heard about the 23 gear getting eaten up too. Is that because it isn't compatible with a 7-tooth drive gear? Does it work with an 8-tooth drive?
1 of 2 Next Last
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Drivetrain 5th Gear Ratio
  • PonyGTrider
  • Dec 8, 2025
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
K
Drivetrain '87 5.0 Installing New Ring Gear and Pinion - Pattern Questions
  • karhoot
  • Apr 23, 2026
Fox 5.0 Mustang Tech May 9, 2026
Mindseye007
Front window issues
  • bruno
  • Nov 7, 2026
Fox 5.0 Mustang Tech Tuesday at 10:26 PM
AeroCoupe
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
