Speedo gear
  • Thread starter Thread starter Z06killinSBF
  • Start date Start date Feb 23, 2008
Z06killinSBF
457
McKinney, TX
Feb 23, 2008
  • Feb 23, 2008
What gear do I need for 4.10's with a C4.
D
D.Hearne
11,730
south louisiana
Feb 23, 2008
  • Feb 23, 2008
If the 23 tooth gear doesn't work, you'd need a reducer combined with a lesser tooth gear to work.
Z06killinSBF
457
McKinney, TX
Feb 23, 2008
  • Feb 23, 2008
Well, maybe you can answer my problem. The tranny I put in my car has a different drive gear in it. With my stock gears (2.80's) and the stock speedo gear, it read about 5-10mph fast. Now that I put 3.80's in it, I am guessing that a speedo gear designed to correct for 4.10's will make the proper correction. Do you agree?
Z06killinSBF
457
McKinney, TX
Feb 23, 2008
  • Feb 23, 2008
Double post
D
D.Hearne
11,730
south louisiana
Feb 23, 2008
  • Feb 23, 2008
All C-4's have a 7 tooth drive gear. You cannot change that, it's machined into the tailshaft. I've got 3.50's in my 77 Comet (C-4 also) and 25.5 inch tires and a 19 tooth gear is the correct one for it.
Z06killinSBF
457
McKinney, TX
Feb 25, 2008
  • Feb 25, 2008
I can only find the closest to be a 21 tooth gear.
D
D.Hearne
11,730
south louisiana
Feb 25, 2008
  • Feb 25, 2008
Mustangs Unlimited sells a 23 tooth gear, this is a non stock gear, Ford's gears go up to a 21 tooth count. There were 16, 17, 18, 19, 20 & 21 tooth Ford gears.
BornInAFord
199
Bend, OR 97701
Feb 25, 2008
  • Feb 25, 2008
Be aware that the 23 tooth gear will wear out very quickly (you may get a few thousand miles out of them), so buy at least two. At least they're easy to change out.
Daniel
New Project Car - The Civil War Mustang
  • TTSaleen
  • Jul 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Today at 11:29 AM
TTSaleen
D
Speedo and tach dead
  • Davinrobinson1
  • Jul 19, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jul 26, 2026
fasterthangas
F
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
3.27 to 3.73 worth it? (Automatic)
  • skidad
  • Wednesday at 11:36 AM
1996 - 2004 SN95 Mustang -General/Talk- Thursday at 12:49 PM
nickyb
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
