  • 1994 - 1995 Specific Tech
Speedo Issue
  • Thread starter Thread starter barthel
  • Start date Start date Feb 11, 2011
barthel
30
Torrance, PRK
Feb 11, 2011
  • Feb 11, 2011
Hey Guys,
I've done a bunch of searches for speedo issues and can't quite find the answer I'm looking for, so I thought I might ask the experts.
My speedo is off by 9 or 10 mph at highway speeds. At 2500rpm's I'm indicating 85mph but only going 75 or 76.
I know that it's possible to change the gear on the trans, but am not sure which one to use.
It's on a '94 GT convertible with an AODE automatic trans.
Any help would be much appreciated.
Pops Fun
961
14
59
Cincinnati, Ohio
Feb 12, 2011
  • Feb 12, 2011
Hi
Have the rear end gears been changed or anything else that might affect the speedo??
Here is a site that offers speedo gears to change the output.
Ford Speedometer Gears for Automatic and Standard Transmission
A more expensive approach is a Ford speedo cal which is electronic for around $130.00 I just did mine.
barthel
30
Torrance, PRK
Feb 12, 2011
  • Feb 12, 2011
Pops,
I don't know if the gears have been changed or not. I'm fairly certain that the tires are smaller (245/45HR/17) and that could be part of what's causing it.
I've only had this car about 6 months and am still learning all the nuances of the Mustang. This car may have been lowered (not sure) but I haven't jacked up the ass end to check the gear ratios yet. I would assume it's stock only because not much mechanically looks like it's been done to this car.
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,373
140
113
Foothill Ranch, CA
Feb 12, 2011
  • Feb 12, 2011
The VSS (vehicle speed sensor) is the part that tells the computer and the speedometer your speed. If your speedometer was bouncing up and down or not working, you might have other issues. But if it appears to be working correctly other than being more off the faster you go, the gear on the VSS is not correct for the gears in the rear end. It is likely you have a gear ratio of 3.73 or 4.10 in the rear end, since those cannot be completely corrected by changing the plastic gear on the VSS. If this is the case, you'll need a SpeedCal or the more expensive Ford version in order to properly correct your speedometer.
Jack up the rear end and
cjrpony
439
West Michigan
Feb 12, 2011
  • Feb 12, 2011
barthel said:
Pops,
245/45/17 is the optional tire size and is correct for your car. So check the rear gears.
toyman
1,944
54
79
Vernon BC
Feb 12, 2011
  • Feb 12, 2011
If the car came from the factory with 3:27 gears (Axle code E it will have a 7 tooth drive gear AODE). If the gears are now 3:73 a 21 tooth driven gear is absolutely correct. No ifs, ands or buts.
Chythar
20+ Year Stangneter
Aug 26, 2004
2,373
140
113
Foothill Ranch, CA
Feb 13, 2011
  • Feb 13, 2011
I thought that all AODE's came with an 8-tooth drive gear. Learn something new every day. You are correct, with a 7-tooth drive gear the 21 tooth is exactly right.
Drivetrain 94 V6 to 5.0 swap ignition / starter wiring
  • Craig12
  • Oct 8, 2024
1994 - 1995 Specific Tech Oct 14, 2024
Mcmahst
Drivetrain GM T56 in a Foxbody
  • AeroCoupe
  • Sep 19, 2024
Fox 5.0 Mustang Tech Sep 20, 2024
AeroCoupe
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 11, 2026
02_2v_Curtis
Questions About T5 Manual
  • Blackout67
  • Apr 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 22, 2025
89ripper
