8 808foxtang New Member Nov 23, 2005 1 0 0 Hawaii Nov 23, 2005 #1 Nov 23, 2005 #1 '91 LX 5.0 speedo needle shakes and is 20mph higher than actual, any suggestions?
SVT32VDOHC waiting for the next hack atta Founding Member Nov 22, 2001 3,501 28 119 Motor City Nov 25, 2005 #2 Nov 25, 2005 #2 The speedo gear one the end of the speed sensor could be bad, if not that check the speedo cable. If not that the speedo could be bad.
04sleeper Founding Member Jun 22, 2002 2,674 14 89 Dallas, TX Nov 25, 2005 #3 Nov 25, 2005 #3 Sounds like your gears have been replaced and someone did not switch the speedo gear. It also sounds like the speedo gear that is in there is worn. I would pull it out and check.
W wazazzle New Member Mar 30, 2005 618 1 0 In the dumpster behind McDonalds. WA Nov 25, 2005 #4 Nov 25, 2005 #4 89sleeper said: Sounds like your gears have been replaced and someone did not switch the speedo gear. It also sounds like the speedo gear that is in there is worn. I would pull it out and check. Click to expand... Same thing he said, is what my suggestion would be.
