speedo not workin
check the wiring to the vss,make sure they are not melted togeather.if they are,seperate them.you may need to replace the speed/rpm gauge in the cluster.i dont know where to get them new.you mabye able to find one at your local junkyard.i think any 94/95 will work,96/98 will also work,but the coolant,abs,ect...icons are in different locations.
your goal is to find a 94-95 150 mph speedo,but if you cant the others i mentioned will work.i had same problem.ran a 95 v6 120 mph for awhile,then a 96 gt 150 mph til i found the proper speedo.there was a 3-4 mph differance between those two and the original.will give you a good ballpark speed til you find 94-95 150 mph speedo
try mpsautosalvage.com for a used cobra cluster,then you can swap out your odometer to that one.just to be safe, make sure the vss wires are ok,otherwise the "new" cluster may be messed up.
