  • SN95 4.6L Mustang Tech
Speedo/odometer faliure?
  • Thread starter Thread starter cobra2798
  • Start date Start date Feb 17, 2009
cobra2798
303
Clermont, Florida
Feb 17, 2009
  • Feb 17, 2009
So I was driving home yesterday and my speedo needle just dropped to 0 and my odometer and trip both stopped working and none have worked since. What causes this and how do I go about fixing it? Thanks
H What 4.6
56
  • Feb 17, 2009
Was your speedo ever corrected for the 3.73s?
If so and you used a speedcal make sure it has power and is still connected properly.
If the speedo gear was changed instead, it may have gotten chewed up.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Feb 17, 2009
  • Feb 17, 2009
The two items H What mentions is what you need to check first. My Speedcal loses contact, I'm guessing form vibration, every now and then and I have to tighten the connections. If you just have the white speedo gear then it is gone. Went through that before I bought my Speedcal.
cobra2798
303
Clermont, Florida
Feb 18, 2009
  • Feb 18, 2009
Speedo was never calibrated for the gears, it was always reading wrong since I bought the car. Is there a fuse that may be blown?
squeak93
2,345
416
164
Joplin, Missouri
Feb 18, 2009
  • Feb 18, 2009
I may be missing something, but he has a mechanical spedo in a 97, a speedo gear is the only way to fix a speedo that is off..... I thought only 99+ cars had elec speedo's...... Again, I may be wrong here. My speedo is correct in my 98 and I don't know of any speed cal on it.... (4.10 gears were in it when I bought it).
98GTfromGA
291
Memphis
Feb 18, 2009
  • Feb 18, 2009
The speedometer and odometer are driven by different gears. If they both stopped working its likely that it is an electrical issue and not a mechanical one. In my car the speedo works but the odometer and trip meter stopped working because the teeth on that gear are worn down. They sell the gears on ebay for like $39.
H What 4.6
56
  • Feb 18, 2009
I'm not sure of the exact logistics of how it is converted from mechanical to an electrical signal, but a 97 has the gear in the trans which goes to the Vehicle Speed Sensor which sends an signal to the speedometer. You can either install a speedcal which taps into the VSS wires to correct the output for the rear end ratio, or install a smaller speedo gear.
The 99+ can correct this through the cars computer via a tuner (XCal, Diablo, Etc.)
cobra2798
303
Clermont, Florida
Feb 18, 2009
  • Feb 18, 2009
Is the speed sensor on the drivers side front of trans, back of motor area? I was looking under the car today and I see a eletrical connector looking thing hanging down in that area. I tried to hook it back up but could not get a good handle on it without jacking up the car and Im at work, dont wanna get dirty. Could this be my problem?
H What 4.6
56
  • Feb 18, 2009
Yes, thats the VSS..... drivers side of trans towards the front... right by the shift tower if i remember correctly
If your saying its not connected? Then that's definitely your problem.
cobra2798
303
Clermont, Florida
Feb 18, 2009
#10
  • Feb 18, 2009
  • #10
Thats it, thanks alot. I wonder how it came loose
H What 4.6
56
#11
  • Feb 18, 2009
  • #11
me too
Let us know how you make out ......... or did you fix it already? haaa
d98gt
4,505
59
204
SE Texas
Feb 19, 2009
#12
  • Feb 19, 2009
  • #12
The vss is on the drivers side . Here is a picture View attachment 270102
cobra2798
303
Clermont, Florida
Feb 19, 2009
#13
  • Feb 19, 2009
  • #13
Fixed, thanks guys
D
Speedo and tach dead
  • Davinrobinson1
  • Jul 19, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jul 26, 2026
fasterthangas
F
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
T
2003 GT cluster issue
  • Timothys gourmet
  • Aug 26, 2025
SN95 4.6L Mustang Tech Aug 28, 2025
Mustang5L5
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
