  • 1994 - 1995 Specific Tech
Speedo Problem Solved...CLUSTER!...What Next?
  • Thread starter Thread starter 94GTLaserRC
  • Start date Start date Feb 21, 2006
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Feb 21, 2006
  • Feb 21, 2006
Well, finally got a hold of a V6 Cluster...slapped it in and it worked. If any of you know about the insides, you know that the there are 3 faces
1. Fuel/temp on the left
2. Oil/Battery on the right
3. Speed/Tach/Odo in the center.
Since the center is a separate piece, both the speedo and tach would have to be replaced, even though the tach side works....There is a small circuit board attached to each one (speed/tach)
The best I have found new for that center piece is $249. My other options are
1. Ebay (only 1 right now...never know whatcha gonna get)
2. what I mentioned above
3. Junkyard- Still not too sure what you get
4. I have a local shop that fixed/replaces clusters...not a bargain company, but "can" do the work.
Any other suggestions/links/prices/etc will be helpful.
Thanks
RC
94GTLaserRC
11,178
Feb 21, 2006
  • Feb 21, 2006
BTW...the cluster PN is:
F4zF-10849-CC
If this helps with searches.
Thanks
SorsCode
20+ Year Stangneter
Jun 10, 2003
1,024
434
113
St. Louis, MO
Feb 21, 2006
  • Feb 21, 2006
Do what I did. Remove the Speedo Needle. Remove the Speedo Section from the V6 and swap it over to the V8. Just disconnect the wiring between the speedo and tach I believe. I did this for the Tach on a V6 cluster so it would read a V8. Since you know the V6 one works us it.
Danny
94GTLaserRC
11,178
Feb 21, 2006
  • Feb 21, 2006
Danny
Well the V6 one was not mine...I just got it to test.
I dont know if the speed translates exactly though..not sure.
Just called the speedo shop..Im looking at $100 to replace the circuit board on the back, have it tested, and get some small type of warranty on the repairs.
I think Ill go that route.
Thanks
RC
SorsCode
20+ Year Stangneter
Jun 10, 2003
1,024
434
113
St. Louis, MO
Feb 21, 2006
  • Feb 21, 2006
Aight. I didn't realize it wasn't urs.
mytight95
2,605
Dothan,Al
Feb 21, 2006
  • Feb 21, 2006
i would go the 100$ route if it came with a warranty on thier work etc. But if i could find one on e-bay, i would try that first, i have bought quite a bit of stuff off there and not been burnt "yet" knock on wood.
you could buy a couple of bad ones until you got a good one off e-bay for less than 100$
jason
94GTLaserRC
11,178
Feb 21, 2006
  • Feb 21, 2006
jason
There are a couple on Ebay right now...$35 and $51 at the time of this, but I expect the $$ to go up another $20 before the end. (Plus shipping)
In addition, I paid a lot of $$ a couple of years ago to replace the little speed gear mechanism. I would RETAIN that if I fix it, and be stuck with old ones if I get a used one (even though I could "tinker" with it and swap it)..Also have the white face decal on my current ones
ANYWAY...I took it in today...the guy tested right on his bench and concurred it was in the cluster...He said he would have it back same time tomorrow.
I may not get it put back in tomorrow, but Ill keep you apprised.
Thanks
RC
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Feb 21, 2006
  • Feb 21, 2006
Good to see you finally made some headway RC
I hate it when a thing like that drags on and on
Grady
94GTLaserRC
11,178
Feb 21, 2006
  • Feb 21, 2006
Grady
WEll, it really only dragged on because of not having time to work on it...then taking awhile to get a cluster to test out. If I had alot of time and the cluster up front, it would have been done right away....Im not celebrating though until it's actually in and running
RC
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
D
66 Coupe Progress Thread
  • DTCRAWLEY
  • Apr 19, 2026
  • 2 3
2K
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
DTCRAWLEY
D
Engine Distributor Interchange List
  • Wayne Waldrep
  • Jun 21, 2025
Fox 5.0 Mustang Tech Jul 20, 2026
dan50
R
1994 GT 5.0L crank no start
  • Red1994MustangGT
  • Apr 15, 2025
2K
1994 - 1995 Specific Tech Aug 19, 2025
Kurt_MO
K
D
Engine 85 GT Backfires through Carb
  • DienstXIV
  • Oct 3, 2025
Fox 5.0 Mustang Tech Oct 7, 2025
85GTStangGuy
