A while ago I read about a place you can get different gears for the trans to make the speedo right again, [after changing rearend gears]. Can anyone give me some direction on this ?
Check to see if there is a speedometer shop in your area. If there is, ask about the Stewart-Warner speedometer gearbox. I believe it is either a 777 Series Drive Joint Kits and Parts or 666 Series Drive Joint Kits and Parts. It is a small gear box that fits between the speedo pickup gear on the transmission and the speedometer. It has quick change gears that allow you to choose almost any tire size and rear end gear ratio you want. This will allow you to get the accuracy with within 2%-3% or less. The drawback is that it isn't cheap.
