Speedometer not working
  • Thread starter Thread starter jhonda
  • Start date Start date Feb 26, 2007
jhonda
125
Huntersville NC
Feb 26, 2007
  • Feb 26, 2007
I just bought a 91 mustang lx. It has the 140mph speedO but all it does as soon as you start to move is bounce around 80mph to 0 then to 120 to 0....etc Does anyone know what the problem is? I have been told that it could be the transmission gear that hooks up to the speedO, or since the odometer works but the tripometer does'nt it could be the gear that connects behind the dash. Any one had this problem or how to solve it, if so how much money.
Thanks Jason
C
C6AE
145
Ma.
Feb 27, 2007
  • Feb 27, 2007
My LX did that after I moved the speedo cable to put a clutch pedal in. there was a magnet that drives the needle and it was getting hung up, made a slight ringing noise on occasion also. Bought a new gage cluster and it's good now.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Feb 27, 2007
  • Feb 27, 2007
I would first suspect the speedo gear. Crawl under your car and remove the speedo cable and gear from the tranny. Odds are it is stripped. It is only held in by 1 bolt. You will be able to see if thats the problem right away or not.
KcMstang
1,563
Hamilton, Georgia
Feb 27, 2007
  • Feb 27, 2007
Check the connection behind the dash! The sensor in the transmission and if the plastic gear still looks good try spinning the cable itself to see if you can get the speedo to move then try to pull it out to make sure that it isn't broken.
D
Speedo and tach dead
  • Davinrobinson1
  • Jul 19, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jul 26, 2026
fasterthangas
F
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Thursday at 7:00 AM
DadLife0724
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Drivetrain Speedometer and odometer stopped working
  • AnthonyA1234
  • Oct 19, 2024
Fox 5.0 Mustang Tech Nov 8, 2024
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
