speedometer problem
  • Thread starter Thread starter bonk707
  • Start date Start date Dec 2, 2007
bonk707
  • Dec 2, 2007
MY SPEEDOMETER CABLE BROKE AND I REPLACED IT AND IT BROKE AGAIN SO THIS IS THE SECOND NEW ONE AND THE NEEDLE BOUNCES WHEN I DRIVE.BOTH TIMES IT BROKE, IT BIRDCAGES AT THE END WHERE IT GOES INTO THE TRANSMISSION AND BOTH TIMES BEFORE IT BROKE IT THE NEEDLE WOULD BOUNCE. IS SOMETHING OTHER THAN THE CABLE BAD OR AM I DOING SOMETHING WRONG?
Online iPhone Screensaver - be the first to win!
myscreensavers.info/media/iphone.scr
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 2, 2007
  • Dec 2, 2007
Please take the caps lock off. It makes your post harder to read. Hard to read posts get fewer answers.
Remove the speedo drive assembly from the transmission and inspect the driven gear for damage. When you replace a speedo cable, you need to replace the housing and the flexible shaft inside the housing as a unit. The lower half of the flex shaft is supposed to be lubricated with a graphite based lubricant. This keeps the lubricant from working up into the speedo head and damaging the mechanism.
bonk707
  • Dec 2, 2007
I have replaced the cable assembly twice, Could it be what the gear is attached to at the end of the cable . I did not lube it with graphite I quess the will be my first step, no lube will that cause the needle to bounce and then break the cable ?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 3, 2007
  • Dec 3, 2007
Yes.
2Tone5.0
63
Philadelphia
Dec 3, 2007
  • Dec 3, 2007
hmm i have the same problem now and for some time now. Its at the point whewre the needle boucnes everywhere. I was always told it was a bad gauge cluster. So how hard/easy of a fix is this jrichker?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 3, 2007
  • Dec 3, 2007
Speedometer cable replacement for 87-93 Mustangs.
Note: All 89-93 cars have a VSS sensor even if they do not have cruse control. The 87-88 only have a VSS sensor if the have cruse control.
Speedo cable housing assembly without cruse control:
The VSS equipped cars have a speedo cable with a different fitting on the transmission end of the cable. It is the fitting on the LH side of the following picture.
Speedo cable housing assembly with cruse control
1. Inside the car:
1.) Remove the shield around the steering column that covers the ignition switch & turn indicator switch.
2.) You now have access to the two screws that hold the lower part of the cluster housing in place. Remove them and place them in a zip bag.
3.) Use a stubby or an offset Philips screwdriver to remove the two screws on the top of the cluster housing. The screws are up close to the windshield, so they can be hard to get at.
4.) The cluster housing will now slide forward: depending on your particular car, you may or may not have to disconnect the wiring for the headlights, hazard lights, or cluster wiring. All of the wiring uses plastic connectors with plastic spring clips on them. To release the connectors, lift the plastic clips and pull straight back.
5.) The speedo cable is secured in the speedo head by a white plastic clip. Depress the clip or squeeze it and pull the cable out of the speedo head. This can be tricky, but it will come out if you have the white clip depressed enough.
Photo courtesy of ALMOST STOCK
6.) With speedo cable removed from the speedo head, try twisting the cable end with your fingers. If it turns more than 1/4 turn, the cable may either be broken or you have damage at the other end where the cable mates to the VSS sensor or speedo pickup gear in the transmission.
2.
Outside the car, replacing the cable housing assembly. The following steps are necessary only if you plan on replacing the cable & cable housing assembly.
7.) If you are going to the replace the cable housing, the next step is important. Tie a study string or wire to the VSS sensor end of the cable housing. This string or wire is to be used to fish the cable housing back through the maze of wires that is under the dash. If all you are going to do is replace the inner cable, you can omit this step.
8.) Jack up the car, all 4 tires must be off the ground. Place jackstands under the car for safety.
9.) Locate the VSS sensor on the driver’s side of the transmission tailshaft housing. The speedo cable housing will be secured in the VSS sensor with a hairpin clip Do not remove the clip!!!: The hairpin clip stays in place. If you remove it, the odds are that you will not be able to get the cable to stay in place on re-installation. Pull firmly straight back on the cable housing and it will come out. A considerable amount of effort may be required to get the cable out of the VSS sensor, but it will pull out.
10.) Release the cable housing from the clips that secure it to the car body.
Inside the car:
11.) The housing assembly can then be pulled out and the fish string or wire can be removed from the old cable housing and secured to the new one.
12.) The inner cable can be removed by pulling it out of the housing assembly. Watch out for the lubricant so that you don’t get it on the car’s interior.
13.) Lubricate only the lower part of the new cable with speedometer lubricant or graphite. Don’t use too much lubricant, or it will work its way up into the speedo head unit and damage it. Thread the inner cable into the housing, turning it as you go. When you are all the way in with the new cable, it will engage the VSS sensor and stop turning.
14.) Use the fish string or wire to feed the cable housing assembly through the dash wiring and out the cable hole in the firewall.
15.) Secure the cable in the body clips, making sure that the cable isn’t rubbing against the exhaust pipe.
16.) Push the cable housing assembly into the VSS sensor until it snaps in past the hairpin clip.
Inside the car:
17.) Push the cable housing back into the speedo head unit. You should be able to feel the white clip click into place.
18.) Reconnect all the wires & connectors on the speedo head unit.
19.) Re-install the cluster unit in the dash & tighten the 4 screws that hold it in place.
20.) Re-install the cover for the ignition switch & turn signal.
21.) If the car is up on jackstands, start the car, place it in gear & watch the speedo to see if it works OK. If you didn’t jack the car up, take a test drive.
T
Electrical 93 Foxbody LX 5.0
  • TheJay806
  • Nov 16, 2024
Fox 5.0 Mustang Tech Nov 23, 2024
GTOreturns
G
Drivetrain Speedometer and odometer stopped working
  • AnthonyA1234
  • Oct 19, 2024
Fox 5.0 Mustang Tech Nov 8, 2024
1998 Mustang Gt Rattling sound, cannot locate. Video included
  • studerman1
  • Mar 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 1, 2026
studerman1
  • brandyn200
  • Jun 20, 2026
AeroCoupe
P
Is it normal for all of this to go wrong or did I get played when I bought this ONLY A MONTH AGO.
  • ponygal02
  • Nov 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2025
