speedometer ratio adapter?
I did a search and think I have at least begun to head in the right direction. I have a 90 GT AOD. It has 3.73s in it. When I had them installed they put in a 21 tooth gear and I was way off. I ordered the black 23tooth from Steeda and that helped but I am still a little off. I called Steeda back and they said that I would be 7% off or so no matter what unless I had a speedometer shop make an adapter to correct this.
My question is what exactly so I need to be lookiing for / asknig for to have this straightened out? I do not want to be putting extra miles on the car and I really don't like being off.
The second part is if I do get it straightened out, should I put the 21 tooth gear in again and have it "corrected even more" so that I dont run the risk of chewing up the 23 tooth gear? My 23 tooth is black I am pretty sure and I have really only read about the white one getting chewed up. I really need someone to point me in the right direction. THANKS in advance.
The stock range of speedo gears work correctly with a limited range of tire sizes. The 23 tooth white gear works good for some guys, but self destructs in a few months for others.
See http://www.corral.net/tech/gearcalc.html for more help
Check to see if there is a speedometer shop in your area. If there is, ask about the Stewart-Warner speedometer gearbox. I believe it is either a 777 Series Drive Joint Kits and Parts or 666 Series Drive Joint Kits and Parts. It is a small gear box that fits between the speedo pickup gear on the transmission and the speedometer. It has quick change gears that allow you to choose almost any tire size and rear end gear ratio you want. This will allow you to get the accuracy with within 1%-3%. The drawback is that it isn't cheap.
Please excuse the typo (their's, not mine) in the following picture - it should read Custom ratio adapters, not Custom radio adapters.
See http://www.gaugeguys.com/ratioadapt.htm for more info.
thanks Jrichker,
I saw your post in my searching. Is the ratio adapters pictured the same as the Stewart-Warner gearbox that you mentioned? Also, am I correct in the assumption that I need a mechanical adapter and not any type of electronic adapter?
I plan on calling the guageguys tomorrow and seeing what they have to say. The problem is I am away from home and my car for a week and can't do the test they are asking to be done ahead of time, but in the same respect would like to get the ball rolling if possible so when I get back I can resolve this.
I wish I knew I could have just changed to a 7 tooth gear in the tranny when I had it pulled apart for a rebuild!!!:bang:
