the entire clusterECU5.0 said:the entire gauge cluster wont light up or just the speedometer?
thankx I will check the fuse's firstECU5.0 said:it could be a fuse, just check them, or it could be a plug....check those too. might have to pull the cluster to see though. check all the fuses and connections that go to the cluster if it comes down to that
thankx will check this tomorrow aswell. have moved the dim light from side to side and nothing but ill see if the other lights turn ontrbkrb said:I assume you checked the dimmer switch, but if that switch fails, it turns out the dash lights AND the exterior lights such as the tail lights. Brake lights still work, but no tail lights with the headlights on. My local law enforcement informed me of that situation. My dimmer switch has one sweet spot where it all works, and the rest of it is basically dead.
Good luck!
89MustangGX said:Oops, wrong thread. I'll check on the fuse and be back.
hehe its coo thankx
