Spider gears
87_stang
131
Tonganoxie, KS
I was also wandering about posi trac and seen 89CobraGT's thread and I'v heard of people welding their spider gears to get a posi trac. Some say its good and also heard its bad. What is your opinions about this? What exactly are your spider gears? I dont know musc about rear ends either.
It's hard to explain w/o a diagram, but the spider gears are the on's between the axels in the carrier. If you welded them, they wouldn't be able to move, therefore the axels would be linked. That isnt' the best or proper way to do it, rigged if you ask me. The proper way is to get a solid spool, saves a lot of weight as well. The axel will operate as one unit, great for straightline acceleration, bad for taking turns as one tire must spin faster than the other durring a turn, something has to give.
I rebuild my traction-loc with an extra clutch pack on each side, made the tires spin equally without the negatives of a welded/solid carrier. Except when wet trying to take a u-turn it could be hairy.
I rebuild my traction-loc with an extra clutch pack on each side said:
How do I go about doing this? I have stock gears in the car and plan on upgrading to 3.73 or 4.10's once im done with everything else. Does it matter if I do it before switching my gears? Thanks for the help:flag:
I dont' know if you'll be able to get the parts from a parts chain. Summit and Mustangs Unlimited sells the kit, it's called a Ford Racing Traction-loc rebuld kit, about $50. Do it now or later, it really doesn't matter, because these dont' need replacment to do a different gear.
