Spindles
  • Thread starter Thread starter Black Sun 5.0
  • Start date Start date Feb 6, 2009
Black Sun 5.0
1,337
L.I., N.Y.
Feb 6, 2009
  • Feb 6, 2009
I ordered and installed Baer's front and rear disk brake upgrade for my '90 which came with Fox front spindles which are modified for 5-lug. As a result, we needed to use spacers on the fronts so that my Bullet wheels would fit. Since I'm not appy with this spacer situation, I want to upgrade to 94/95 spindles. To complete this upgrade, what other accessories or parts will I need? Thanks.
Black Sun 5.0
1,337
L.I., N.Y.
Feb 6, 2009
  • Feb 6, 2009
No takers? I figured this wan an easy one, 5-lug Fox spindles to 5-lug 94/spindles and associated parts.
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Feb 6, 2009
  • Feb 6, 2009
The problem is the rotors. They are the 13" kit correct?
You'd need SN95 spindles and 13" Cobra rotors. The baer calipers are the same as the Cobra calipers so they should bolt right on assuming Baer didn't do something crazy and add a custom bracket.
Then sell the Fox-based spindles off and recoop some of your money
D
DonMaximo
217
Lewisville, Texas
Mar 7, 2009
  • Mar 7, 2009
I have a 1992 with 94 spindles. I am however, using Stainless Steel brake system and needed a spacer for my Bullet wheels to clear the larger calipers.
The problem I now have is that the wheel is pushed out beyond the fender. Rolling the inside lip will not solve the problem. I bought used fenders to modify and see if I can't expand them, but the more time I test... and consider this option... the less reasonable it seems to be a solution.
I'm next going to see if the 95/96 spindles have a slightly different profile that will allow the wheel to fall under/within the fender. For some reason, I seem to recall someone saying that are more shallow than the 94's. Not Certain though.
I will be keeping an eye on your thread.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Mar 7, 2009
  • Mar 7, 2009
The 96+ spindles will exacerbate the problem, since they have a wider track width than the 94-95 spindles.
Nova
128
  • Mar 8, 2009
here are the ford instructions for the m-1300-k kit
http://www.fordracingparts.com/download/instructionsheets/FordInstShtM-2300-K.pdf
heres another write up:
79-93 5 Lug Ford Fox Body Mustang Conversions
D
DonMaximo
217
Lewisville, Texas
Mar 11, 2009
  • Mar 11, 2009
Yup !! I figured that out about 1-2 hours after my post.
So I spent the day on Saturday pounding metal with hammers and dollys to push out a flare and it came out tremendously well...will require very thin film of filler at best.
Thanks for the follow up
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Mar 11, 2009
  • Mar 11, 2009
If your are running 17X8 Bullit wheels up front you can run 94-95 spindles or 96-04 spindles. The 96-04 spindles push the wheels out 13mm over stock fox. The 94-95 spindles push the wheels out 5mm over stock fox. 96-04 increase the track width 8mm over 94-95 spindles.
Either way, the front wheels will not stick out. But if you go 17X9 up front with 96-04 spindles, they will stick out.
You also need 94-04 ball joints in the lower control arms, of just buy spacers and place them on top of the ball joint after you set the spindle on it. These spacers place the crown nut upward so it is aligned with the cotter pin hole.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Mar 12, 2009
  • Mar 12, 2009
Another problem with 96-04 Spindles used with the Stock K Member is increased Bumpsteer!
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
J
Wheels-Tires Need Some Help - Brakes Upgrade/Wheel fitment
  • jaygee15
  • Dec 8, 2025
  • 3 4 5
4K
Fox 5.0 Mustang Tech Oct 6, 2026
jaygee15
J
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
