So you sent it and it went through? But I havent got it yet or something? Man this is confusing. So you dont have AIM or ICQ?
Dave
Dave
Anyways i think i am going to order some spintechs now
Stupid me, hopefully I will save it next time he I talk to him.88SC_GT said:ill let you know how it turns out. my subframes are probably 1.5" thick. the question for me now is, how much do i need to take off?
ironheart, this should bolt right on fine, but do you want side exhaust or just a normal catback?
Michael Yount said:Ironheart - long tubes make MORE low end torque, not less. MM&FF's header test last month had the long tube BBK's making almost 40 lb-ft more torque at 3000 rpm than the shorties. That increase disappeared as the revs went up - tests run on a 347.
Spin tech makes oval pipe and fittings. If you're not already using them, and you're looking for more ground clearance, you could run their 2.5" round to oval adapater on the outlet of the muffler, and then run oval pipe/ell to get to the side in front of the rear tire. Probably pick up at least an inch of clearance that way.
