Split Bellhousing
  • Thread starter Thread starter COBRAIIW
  • Start date Start date May 3, 2006
C
COBRAIIW
562
CT
May 3, 2006
  • May 3, 2006
Has anyone tried to use or make a split bellhousing for the four speed?
That idea seems to be the easiest way to go when you are running headers, and need to work on the clutch/pressure plate.
Last time I tried to remove mine, I had to move the headers, raise the engine, and other parts just to get room.
Any thoughts?
Wart
I'm Mad as HELL and I'M not Gonna Take it ANYMORE!
408
NE Ohio
May 3, 2006
  • May 3, 2006
I think you would be trading one problem for another, and you might get something worse.
It wouldn't eliminate the getting to the bell to engine bolt problems, and you would be adding the problem of bolting the halves together and getting to those bolts. The bell would have to be thick enough for the bolt bosses and threads making the bell heavier. Some of this weight may be needed to handle transmission of the transmissions torque to the engine.
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
1998 Mustang Gt Rattling sound, cannot locate. Video included
  • studerman1
  • Mar 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 1, 2026
studerman1
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
