Spool on street?
  • Thread starter Thread starter srt6
  • Start date Start date Oct 26, 2008
srt6
10
  • Oct 26, 2008
Question is this. I bought a drag car with 4.10s and a full spool. Will the spool make it impossible to drive on the street? It's an AOD car and I just need to get back and forth to the dragstrip. I have no experience with spools at all so any experience would be appreciated. Nows the time to yank it if it makes it a trailer queen.
myslo50
247
ohio
Oct 26, 2008
  • Oct 26, 2008
i would drive it. try it, if u dont like it ditch it. i heard its a pita when turning hard turns. i thinking about going spool, im tired of messing aroung with the track lock in mine.
ChromdOutDubs
268
Tavares, Florida
Oct 27, 2008
  • Oct 27, 2008
I drove mine on the street with my full spool before I went full race. It wasn't to bad just driving around town. It does get worse when your trying to make tight turns in parking lots. You just have to remember to get rolling before you try to turn the wheels.
-AJ
2000xp8
SN Certified Technician
Aug 8, 2003
8,060
1,645
194
NJ
Oct 27, 2008
  • Oct 27, 2008
It's not a good idea. Get an eaton posi unit.
57fairlane
560
Oakwood, GA
Oct 28, 2008
  • Oct 28, 2008
I wouldn't do it on a daily driver but on a weekend car its fine.
I had one in my falcon that was pretty easy to drive with a auto and only slightly tricker with the stick (mainly backing up). If you don't mind it, keep it. I would re-do a spool on any weekend car in a heartbeat.
PUNISHER RACING
1,124
FORD CITY, PA.
Oct 28, 2008
  • Oct 28, 2008
I have done it for years. It can be a pita if the weather gets wet, or you are making real tight turns. With the better c- clip elims. they make today things go a little smoother and with less leaks. The more sidewall your tire has and the softer it is the better. Either way the spool or the Eaton you will have great results one is just a little cheaper.
C
Electrical Under dash wiring
  • ChicagoMustang
  • Apr 17, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 4, 2026
JD1964
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 22, 2026
PNN
P
