Hey guys, I've been trying for a while to try and put together a suspension package for my 66.
First and foremost I need to get new springs.
I can push my car down at least an inch on every side, and according to suggestions that means that the springs are worn out.
Second, i don't think i need new shocks cause after i push the car up and down it stops instantly.
Third, the car in the rear doesn't sit level its a tad lopsided, and the passenger side tire feels closer to the fender than the driver side rear tire.
I looked at mustangsplus's GRAB a Track kit and it sounds awesome.
Mustangs Plus :: Suspension and Handling :: Spring & Handling Kits :: 1965-66 Grab-A-Trak® Spring and Handling Kit
The parts include :
* 620 front coil springs
* Performance 4-Leaf Standard Eye Leaf Springs
* 1” Front Sway Bar
* ¾” Rear Sway Bar Kit
* Front and Rear Shock Absorbers
* Polyurethane Coil Spring Insulators
* Polyurethane Sway Bar End Link Kits
* Polyurethane Sway Bar Frame Bushing Kits
* New Leaf Spring Shackles with rubber bushings
total: 489+80 (shipping)=569$
I then told myself let me check NPD since i have one nearby, i can just pick up the parts. They don't have a kit so I asked them for their input and help to try and rival MP's kit;
They answered:
" We only offer a 1” lowering spring with a 480 rate. The 620 rate coil springs will be very harsh. The shocks on this list are KYB brand “Gas-a-just”. We can go cheaper if need be but these are excellent shocks. Everything else should be compatible or even the same brands as the other company. "
The parts list included:
-Coil Spring set, high rate, grey pair. (74.95)
-Inulator, polyurethain coil SPR pair. (13.95)
-Sway bar kit, front, 1 inch (139.41)
-Leaf Spring OE design (127.00)x 2 = 254
-Shackle Kit, leaf spring, rear (14.95)x2 = 29.90
-Sway bar kit, rear, 3/4 inch (108.91)
-Shock set, KYB, Gas-a-just, 4 PI (174.95)
The total is
796.07+24 oversize, and 30 freight = 850.07
Now, I'm looking for some guidance, I'm not sure why there is such a huge discrepancy. I don't want to to spend 850.07 on parts only...
And about the spring rate, is it true that grab a track will be too stiff? This is going to be a cruiser/weekend warrior, i'm more focused on comfort and tires not rubbing.
Should i replace the shocks at the same time as the springs? (the current shocks don't seem to be stock they're red)
And what about the sway bars, do they really need to be replaced? When i got a quote from another guy he said the previous owner spent a lot of money on this car and the only thing that needs to be replaced was the idler arm. But i'm not sure how reliable he was.
Any input is appreciated. TIA (sorry for the long post)
The parts include :
* 1” Front Sway Bar
They answered:
The total is
