spring compressor?
  • Thread starter Thread starter kreacher5.0
  • Start date Start date Jun 25, 2006
K
kreacher5.0
122
  • Jun 25, 2006
Were can I get one that works on the mustangs.
HISSIN50
34
129
Jun 25, 2006
  • Jun 25, 2006
The clamshell compressor is hard to find and costs a couple hundred bucks (last time I took a peek).
A modified internal spring compressor can work, and some like to use the MFE method.
Good luck.
K
kreacher5.0
122
  • Jun 25, 2006
whats the mfe method
K
kreacher5.0
122
  • Jun 25, 2006
I cant even find an internal spring compressor
K
kreacher5.0
122
  • Jun 25, 2006
well I dont have to have the clam shell type i need the ford tool t82p-5310-a
K
kreacher5.0
122
  • Jun 25, 2006
anybody know were i can get this tool
Mustang5L5
Mod Dude
Feb 18, 2001
43,377
18,123
224
Massachusetts
Jun 25, 2006
  • Jun 25, 2006
I've never even used a compressor to do springs on a Mustang.
The rears are a joke to do and the fronts can be done sans compressor if you lower the a-arms down
K
kreacher5.0
122
  • Jun 25, 2006
well im trying to get the stock spring in ive tried to lowering the arm as far as it goes then try to pry it in but no luck
xpeteyjtx
108
Taunton, MA
Jun 25, 2006
  • Jun 25, 2006
With the strut attached and the tie rod removed you must remove the a-arm bolts and lower the a-arm. It is best to lower the a-arm with two bottle jacks, one on each tail of the a-arm. When raising the a-arm back up, use a crow bar between the a-arm and k-member to align the a-arm holes. This is the only way to get those suckers back in without the proper spring compressor.
rd
3,316
63
109
Ocean Springs MS
Jun 25, 2006
#10
  • Jun 25, 2006
  • #10
I have done this several ways. The Ford tool is pricey, its an internal compressor with rounded plates that fit the springs nicely, and ball joints at the nuts where you tighten it.
Shorter front springs can be installed without a compressor, you remove the sway bar, tie rod, and lower strut bolts. Insert the spring and coax it into both spring pockets and jack the lower arm back up. It still can be a mother.
I ended up taking two pcs of 1/2 in thick steel, about 2 by 5 inches, and putting a hole in the middle for 5/8 or bigger threaded rod. This is the country boy spring compressor. I cpmpress the spring in my press or by tightening the nuts before I install it. Make sure the long end of the rod sticks out the hole in the lower arm.
The country boy would jack the spring under the trailer hitch to an F250 as tight as possible and wire it closed with coathangers or short pieces of chain. I have not done this one, but others have and it works. A steel banding tool is considered the ultimate for this approach.
I also have the KD tool, and it would work but the threaded pcs with the hooks are too big to remove through the hole in the lower arm. You could just get one of these and enlarge the hole.
fidstang
307
South Lansing
Jun 25, 2006
#11
  • Jun 25, 2006
  • #11
I just seen the rounded plate internal compressor at autozone and one at Murry's. I'm a Murry fan over autohoe's any day. But both were identical.
HISSIN50
34
129
Jun 25, 2006
#12
  • Jun 25, 2006
  • #12
The Ford one has been called a clamshell compressor.
The MFE method is widely known on the Corral (he's a mod there). Guys are talkin about it here - using the LCA to compress the spring rather than compressing it statically.
Fidstang, I'll have to see if I can find that compressor at AZ - sounds like it might be useful.
Good luck.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Jun 26, 2006
#13
  • Jun 26, 2006
  • #13
I bought the Ford one last year from a tool company on the net, it was over 200 Bucks, but was worth every penny as it really made changing the fronts easy!
whtpny
338
Spokane WA.
Jun 26, 2006
#14
  • Jun 26, 2006
  • #14
I used some muffler clamps. Put them over two coils, put the nut on, tightened with air ratchet and sucked t down, lowered A arm the removed spring. same for install. Fast and cost less than 10 bucks!
tunedin302
I AM the law!!!
Jul 29, 2004
1,251
Pennsylvania
Jun 26, 2006
#15
  • Jun 26, 2006
  • #15
Never had to use a spring compressor to remove them. However, to put in the Eibach I had to use a spring compressor. If you are looking for a compressor, I used Eastwoods. They have two styles - one that clamps from the inside and another that clamps from the outside. I used the one that goes on the inside of the spirngs.
http://www.eastwoodco.com/jump.jsp?itemID=2454&itemType=PRODUCT
http://www.eastwoodco.com/jump.jsp?itemID=2488&itemType=PRODUCT
NosPony
278
Canton, Il
Jun 26, 2006
#16
  • Jun 26, 2006
  • #16
rent one at autozone for 50 bucks that is what i did.
Flavadave4
1,044
21
49
Utica, NY
Jun 26, 2006
#17
  • Jun 26, 2006
  • #17
I used a pry bar........worked fine
OonDeanisS
902
Danbury, CT
Jul 1, 2006
#18
  • Jul 1, 2006
  • #18
i got one at autozone on rental 10 minutes ago, and im starting the job tonight, getting in my Eibach road race springs finally!
94 Cobra 5.0
114
Ft. Riley, KS
Jul 1, 2006
#19
  • Jul 1, 2006
  • #19
Did mine a couple of times and i used a cheap fix. bought some motorcycle straps wrapped them around the inside of the coils and started to tighten them down. stick the spring in the top of the spring pirch push the spring into the arm and jack it up. done this a couple times like i said and never had a problem.
K
kreacher5.0
122
#20
  • Jul 2, 2006
  • #20
well i got my c springs in and i didnt even need a compressor the car rides real nice compared to the wore out 4 cyl springs anyway thanks for the info guys
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
2010 GT AC issue
  • 2010torchredgt
  • Jun 28, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Jun 29, 2026
2010torchredgt
Suspension Installing stock springs on my 86 GT
  • Canyonred86
  • May 14, 2025
Fox 5.0 Mustang Tech May 19, 2025
Mustang5L5
2001 v6 New compressor issue
  • badmech
  • Apr 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 30, 2026
badmech
E
Serpentine ac bracket differences
  • EspaceF1Fan
  • Apr 1, 2026
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Apr 1, 2026
OX1
O
