nickthegenius said:Am I understanding correctly that you unbolted the control arm to install the spring and it wouldn't line up? If so, what possessed you to do that? Put the rear framerails on jackstands, unbolt the bottom of the shocks, lower the rear end with you jack, and the springs should flop out like Janet Jackson's breast.
have you ever lowered a stang?????? cause simply unbloting the shocks wont do jack, cause they are still attached to the axle & the control arm is attatched to the axle. in order to get them out you have to take one bolt out of the control arm & let it down to release pressure on the spring
*at least thats the only was i saw to do it*
