Spring install using a spring compressor.
supergoat
34
So I'm going to attmept this in my apartment parking lot tomorrow.
If I have a spring compressor can I do this by only lifting one corner of the car at a time? Any instructions, including short cuts, for a spring install when using spring compressors?
I have a two piece kind of compressor, one for each side of the spring if that helps.
Thanks! I searched, and read a lot of GOOD info but would like some info pertaining to ways to "cheat" with a spring compressor. :D
The front I'd like to do one side at a time, but I'll jack both sides of the rear as I'll be installing an ADDCO rear sway bar as well.
Mel96GT
255
San Diego
It's a lot faster if you don't use a spring compressor. Just disconnect everything (brake calipers, swaybar, strut, etc.) from the spindle to give you enough play to lower the lower A-arm enough to remove the spring. That's the way I've done it to install some Mach 1 springs. The spring compressor seems like a PITA.
DTNODYA
831
I rented a spring compressor when I did mine .... Attached the compressor and started to lower the A-arm ... The compressor exploded into 50 pieces! So I did not use one. I just let the A-arm down slowly while holding my foot on the spring (thinking it was going to shoot out) and it just kinda goes "thump". I've done this on a few Mustangs without incident. Just let the spring decompress SLOWLY!
supergoat
34
I was defeated by the brake caliper. I could not brake it loose from the rotor. So I decided to just take the top part off since that's where the hose goes to anyway.
The bolts to do that just spun and spun.
supergoat
34
Nah they are fine, I figured it out. They have to be removed differently than the ones I'm used to. So I could probably go do the springs now but I'm already inside and everything is back together. I think laziness is going to win.
Mustang5L5
Mod Dude
Feb 18, 2001
40,022
15,730
224
Massachusetts
I never use a spring compressor for spring installs. If you are installing lowering springs you really don't need it.
The rear springs are a joke to do. Just disconnect the shocks and quad shocks and sway bar and lower one side down at a time until you can pull the spring out by hand
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
i didnt use a compressor either. i was going to suggest attaching the compressor to the spring when the A-arm is still putting pressure on the spring so that when you let the arm down (SLOWLY!!) the spring would stay a little compressed and come out easier. Your new ones should go in a lot easier since their shorter then the stockers.
tomustang
Psychotic Member
3,434
McLean Hospital
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Uhh try that same principal on my Audi front strut then go to my cobra's struts, completely different
Like others said, you don't need to use a compressor
look at the thread title, he wanted to know how to use the compressor. all struts need to be compressed, one way or another. if you can do it without a compressor, good for you. if you have a strut assembly out of the car, they all come apart the same basic way......
timeless2
Vi Veri Veni Versum Vicus Vici
Admin Dude
197
154
the Shadow Gallery
Take a deep breath...
