spring shock strut question
it has swaybay struts shocks and springs. in a sn car they lower about an inch. in a fox i dont think it will lower it at all. the shocks and struts are specially valved for the springs. (i have done some research) I decided to go with fms c class springs cause they lower more and have a similar spring rate to the bullitt/mach 1 springs. you can get the shocks and struts by them selves for around 200 i think through downs ford. i have not picked up any yet.
Kerpal said:
What does the "Bullitt suspension" consist of... just different springs and shocks? Are the springs the same as FMS B springs or something else?
It came with Springs, Struts, and Shocks. The Shocks and Struts are Tokicos, after install on my 92 GT they dropped the car about 3/4" all the way around and the car has a slight rake, the front is 1/4" Lower in the front than the rear. Some so called Bullitt kits are thrown together pieces and have some Mach 1 parts and may not lower a Fox Body at all, but I got the real Bullitt stuff!
