  • SN95 4.6L Mustang Tech
spring swap
  • Thread starter Thread starter venom5sc
  • Start date Start date Oct 20, 2004
V
venom5sc
15
  • Oct 20, 2004
If the springs are changed in a mustang should the shocks be changed as well say for a 1 inch drop? Also, what brand would you recomend...Eibach, bullit, mach1.....something else?
twogts4us
4,188
12
79
Dunedin, FL
Oct 20, 2004
  • Oct 20, 2004
Welcome to StangNet!
For a 1 inch drop, the Bullitt or Mach 1 setup is a great choice and awesome value at about $400 for shocks, struts and springs.
M
md1198p
114
  • Oct 21, 2004
where is a good place to order this from? also, how much better is the mach one setup for the track? i know it will handle better, but does it launch better?
V
venom5sc
15
  • Oct 21, 2004
Thanks for the welcome. I seen a few posts on the bullit and mach 1 suspension kits. There was also talk about using the bullit springs and struts with the mach 1 sway bar, any comment on this? Ive seen the bullit kit for sale on v6mustangstuff.com for $400. Is there other places or do you buy the parts from the dealer?
Marks5.0!
640
San Antonio, TX
Oct 21, 2004
  • Oct 21, 2004
bullitt 1" drop
mach1 1/2" drop
you can get the mach1 springs and shocks/struts for 290 from randy over at modulardepot.
M
mrpositraction
296
Columbia, MO
Oct 21, 2004
  • Oct 21, 2004
I did a 1.5" drop and left the stock struts/shocks in and havent had a problem yet. When they do go I will get Bilstien.
Welcome to Stangnet.
M
md1198p
114
  • Oct 21, 2004
so which suspension performs better at the track, bullit or mach?
Marks5.0!
640
San Antonio, TX
Oct 21, 2004
  • Oct 21, 2004
if i remeber right the springs rates for bullit and mach1 are the same rates or very close to each other
twogts4us
4,188
12
79
Dunedin, FL
Oct 21, 2004
  • Oct 21, 2004
When you say track, I trust you mean drag strip - if that's the case, you might want to consider Fox springs or all out drag springs. With the Fox springs, you want 4 cyl springs out front, and V8 springs in the rear. Minimal coil cutting will be necessary to get the ride height you want, but you get the best of both worlds here - you get rid of the 4X4 look, good weight transfer, plus it doesn't lighten the wallet to much...especially if you don't mind taking a trip to the junk yard. Add Strange 10 way adjustable shocks and struts ($350 for the whole set) and you've got yourself a pretty inexpensive setup that will look good and perform well.
Head over to www.modulardepot.com, sign up and browse the forums. Take a look at drag racing forum - do a search for 'fox springs'.
Also, I'd think about aftermarket contol arms, for starters....
Enjoy!!!
N
Fox Street Suspension Build Advice
  • NYFox
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
E
4.6l auto to 5.4l 6 speed
  • EastanF5
  • Jan 22, 2026
SN95 4.6L Mustang Tech Jan 22, 2026
EastanF5
E
F
For Sale 03 Redfire Cobra Convertible
  • FastFox5oh
  • Jul 14, 2026
SN95 Mustangs For Sale (1994-04) Jul 14, 2026
FastFox5oh
F
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
