springs
They are for quelling harmonics. But as I'm sure you will hear, folks have removed them and not noted any difference.
I would leave them though - Ford put them there for a reason (even if we can't perceive what they're doing). Figure 50 cents (or whatever) times a zillion cars and it was a lot of expense. It was done for a reason.
MHO.
Good luck.
if you're talking about the rubber tube inside the spring itself and not the top and bottom spring isolators then i removed mine with no ill effects. I know ford put them there for a reason, but what reason? i cant see a piece of rubber helping anything except for small vibrations in the spring..on a heavy car it wont make any difference...i took mine out so it looks cleaner and i could paint the spring inside and out
~Mark~
~Mark~
That's exactly why they did that. Do dampen any vibration and sqeaks. Most people only remove the right rear isolators to get a better launch and stance for drag racing.
