  • 1994 - 1995 Specific Tech
Squeaking throw out bearing?
  • Thread starter Thread starter Scot_94GT
  • Start date Start date Aug 28, 2004
Scot_94GT
262
Spring Lake Park, MN
Aug 28, 2004
  • Aug 28, 2004
For some reason, by cra makes a preiodic squeaking noise, that it relative to engine rpm. I thought at first that it was one of the pullies on the serpentine belt, but I noticed that the niose was coming form underneath the car more than under the hood. THen I also noticed that the squeaking only occured when the clutch was out and my foot was not toutching the pedal...if I toutch the pedal a tiny bit (just barely putting pressure on it), the squeaking stops. This leads my to belive that the throw out bearing is bad. Does this sound right to anyone else? Could my problem be fixed simply by adjusting the clutch so that there is always a tiny bit of pre-load on it, or is that a no-no that would wear out what's left of the life on my T.O. bearing.
I really don't know if the bearing is bad, or if it just needs adjusting. If it helps, my car is a '94GT with all original equipment, and has 56,000 miles on it. SHouldn't the drivetrain components last longer than 10 years and/or 56,000 miles?
Thanks
-Scot
JJ95GTID
1,141
Phoenix, AZ
Aug 28, 2004
  • Aug 28, 2004
Mine did the same thing. It is the TO bearing. It is only going to get louder over time. There is no adjusting the bearing. They come prepacked with grease. You can apply lube to the input shaft tube that the TO bearing rides on but that is only to allow it to slide easily while engaging the clutch. I went ahead and installed a FRPP King Cobra clutch kit since the tranny had to come out to do the TO bearing. The kit comes with a new TO bearing as well as a clutch disc and pressure plate assemblies.
Scot_94GT
262
Aug 28, 2004
  • Aug 28, 2004
So there is no way to adjust the clutch so that there is always a slight preload?
JJ95GTID
1,141
Phoenix, AZ
Aug 28, 2004
  • Aug 28, 2004
Not on a stock clutch setup (it is self adjusting). You can get aftermarket clutch items like a firewall adjustable clutch quadrant and other types.
SN95Oh
91
Oklahoma
Aug 28, 2004
  • Aug 28, 2004
Yeah you can adjust the cable to just a little bit to shut the TO bearing up. But You would still want to replace it
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Aug 29, 2004
  • Aug 29, 2004
A tip on the tb for you.
I've seen countless threads where people say that with just very few miles after installing a new tb it started to make noise.
The fix seems to be that you want to only use a Ford tb cause they hold up better than the others.
Later
Grady
P
purple86
  • Aug 29, 2004
On a stock clutch set up, the only thing you can try is to push your clutch padel to the floor and let your foot slip off of it. That is the only way you can adjust the stock clutch. That is with out an adjustable cable. I don't think it will help your problem but you can try.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Aug 29, 2004
  • Aug 29, 2004
There is already a little "pre-load" on the cable as it is, and the TOB is just barely touching the PP fingers. That is why you hear the squeak. When you push the pedal a little more, the TOB completely contacts the PP fingers and spins on the bearings.
The temporary fix is simple. Put some wheel bearing grease on the front of the TOB where it contacts the PP fingers. You do this when you install a new TOB, and this should remove the squeaking.
If you don't, the TOB will break soon. I just kept driving on my squeaking TOB, and when it broke, it came out in pieces, literally.
Just remove the clutch dust cover, and get some wheel bearing grease on the front to the TOB. This will increase the life on your TOB, and will delay fixing the car in haste.
But it will break eventually. So save up the money for a good clutch (Spec stage 1, or king cobra) & replace it before it breaks. You will be happy you did. When mine broke, I had to shift w/o using the clutch. Not a fun experience.
Scott
9
94whitesnake
152
Allentown, PA
Aug 29, 2004
  • Aug 29, 2004
another thing that isn't a fun experience is replacing the clutch.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Aug 29, 2004
#10
  • Aug 29, 2004
  • #10
Very true. But once you do it, removing the entire rear drivetrain will be a piece of cake for you (or whomever). The few little things I have learned would make the removal/installation a breeze. If you have any questions, or want tips, PM me.
Scott
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
H
New kid on the block
  • HydraX
  • Mar 22, 2025
  • The Welcome Wagon
The Welcome Wagon Mar 22, 2025
HydraX
H
Progress Thread "Alter Ego" White 1993 LX 5.0 5spd
  • idareu
  • Sep 9, 2024
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 19, 2025
idareu
J
  • JRC99
  • Apr 19, 2025
JRC99
J
