squeaky sway bar
  • Thread starter Thread starter tomcatgt
  • Start date Start date Dec 11, 2004
T
tomcatgt
59
Oklahoma
Dec 11, 2004
  • Dec 11, 2004
Put a new 1 " sway bar and bushings on this spring. About a month ago started getting a terrible squeek from the front end. It's both the bushings where the rod connects to the frame. Has anyone had the same problem? I pulled em loose and sprayed em with silicon and that has fixed it , at least temporaily. Any permanent cures available? Used the ones that came with the kit and sure don't want anymore of them.
Tubo(2-bo)
279
Ft Walton Beach FL.
Dec 11, 2004
  • Dec 11, 2004
Lithium grease works well
66stangmeister
226
Lafayette, LA
Dec 11, 2004
  • Dec 11, 2004
yeah, i put super grease on mine when i replaced the front sway bar. that should work.
F
fst68pony
  • Dec 11, 2004
I had the same problem, until I pulled the sway bar inner mounts off and took a dremel tool and carved a channel in the middle of the urethane mount the full inner circumference. Then drilled a hole through the metal cup of the mount the size needed to tap a grease zert into, now in the winter when things begin to make noise I just give a squirt of grease from the grease gun and front end stays quiet!
Rent-A-Racer
187
  • Dec 12, 2004
great idea! I just may have to steal it
G
Front Sway bar HELP
  • Grabberblueguy77
  • May 28, 2025
2005 - 2014 S-197 Mustang -General/Talk- May 28, 2025
gkomo
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
M
  • mnky99
  • Sep 5, 2025
mnky99
M
