  • 1994 - 1995 Specific Tech
squealing clutch
  • Thread starter Thread starter 94 BLU GT
  • Start date Start date May 8, 2006
9
94 BLU GT
Vancouver
May 8, 2006
  • May 8, 2006
hello,
When I push the clutch pedal in on my 94gt 80,000miles , it makes this bad squealing noise. the sound goes away alittle bit as car is driven awhile, but it seems to be getting worse and worse as time goes on. My clutch isn't slipping or anything and seems to be solid. What is this? And should I be worried (Am i doing any damage by driving it?)
thanks in advance..
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
May 8, 2006
  • May 8, 2006
94 BLU GT said:
hello,
thanks in advance..
Sounds like your throwout bearing is going south. And yes, you should be worried about this. If the TOB goes, you lose your clutch. If you are thinking of getting a aftermarket clutch kit (pressure plate, clutch disc, TOB), order it now. If you want a stock replacement (i.e. autozone/ford/etc), pick it up asap.
Gonna swap it yourself?
In the mean time, if you have to drive the car, don't use the clutch unless you have to. Leave the trans in neutral at stoplights, slow down way before a red light so hopefully you won't have to take it out of gear.
Scott
94-302-vert
1,947
NE CT
May 8, 2006
  • May 8, 2006
Hogwash....
My TOB has sounded horrible since I bought the car... That was 19k miles ago. Now the guy said that he replaced the clutch jsut before i bought it but it doesn't grab ofr anyhting so if he did something ain't right...
What I did for peace of mind is work on shifting without the clutch so that should I have to I can get it home after hours (ya know when you don't actually stop at stop lights)...
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
L
2006 mustang gt has high clutch bite
  • leevikisley
  • Feb 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Feb 22, 2026
leevikisley
L
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
90Gt squeal/chirp when hot
  • Bvoss59
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 14, 2025
General karthief
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
