Squeeking Belt Problems... LONG
  • Thread starter Thread starter afast93stang
  • Start date Start date May 18, 2005
afast93stang
1,407
North Texas
May 18, 2005
  • May 18, 2005
Squeaking Belt Problems... LONG
First of all, here is what is going on. Before last weekend I had no squeaky belt issues at all. Last Friday I put on a new harmonic balancer because my old one was shot. At the same time I put on a new factory length Gates belt.
I do have a set of MAC under drive pulley on the car (crank and water pump only). I called MAC just to make sure on the belt length and they said stock would work. Their customer service sucks, the guy kept me on hold and then asked me to call back in 15 min...
And the old belt was thrown out in the trash by my mom. DOH!
When I got everything back together it was squeaking. I rechecked everything and everything is tight. I thought it might be the belt so I went and got a stock Ford belt from the dealership. Still squeaks. I went to AutoZone last night and put 4 other belts on, 2 steps up from stock and 2 steps down, all belts still squeak. I also sprayed WD 40 on my belt like the guy at AutoZone said and I still get the squeak.
It gets even louder when the A/c is on and the A/c clutch/pulley is only 2 years old.
I did notice my crank pulley wobbles a little now but the balancer does not. The belt tensioner is almost at its limit where the arrow points between the 2 notches on it. I also dont have the original pulleys, when I bought the engine it already had the MAC ones on it.
Any one have any ideas or suggestions?
feifong
319
mesa
May 18, 2005
  • May 18, 2005
buy another idler
jb89coupe
416
CT
May 18, 2005
  • May 18, 2005
Take the belt off, and try turning your accessories by hand to find what's squeaking. The idler pulley is a likely suspect. Also if your crank pulley is wobbling it's probably not on right..
afast93stang
1,407
North Texas
May 18, 2005
  • May 18, 2005
The crank pulley is on flush and bolted down with locktite. I have hand turned the other pulleys and they dont produce any nioise.
One more thing I noticed is that the idler pulley, when I first put the belt on has room between the 2 markers and doesnt make noise when the engine is running. It only start when the A/c is on and thats when the idler moves to the extreme edge of the marker.
Ourobos
260
May 18, 2005
  • May 18, 2005
Make sure you dont misalign the belt. You can have it off 1/2 of a rib on any accessory, and it will do exactly as you described. If you look closesly, the belt can sit either right up against the pulleys, or out on the first rib.. Make sure they're all the same.
camarokiller5.0
48
Dallas
May 18, 2005
  • May 18, 2005
pulley wobbles a little, that is not normal, you shouldnt have any pulley wobbling, pull it off and see why it wont sit right, i have mac pulley also, removed smog pump, i use a 827 size belt from goodyear, took me several belts to find the right size, good luck!!
afast93stang
1,407
North Texas
May 19, 2005
  • May 19, 2005
Im glad I went and bought a new set of pulleys, it turns out it was the crank pulley making the noise.
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Y
Engine 1994 Ford Mustang Gt Rod Knock/Stuck Lifter
  • yaboity
  • Jun 7, 2025
1994 - 1995 Specific Tech Jun 8, 2025
AeroCoupe
H
1966 mustang starter and pulley troubles
  • Hotrods4ray
  • Sep 24, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 10, 2026
Realmongo
