  • 2005 - 2009 Specific Tech
Squeeking Headliner
  • Thread starter Thread starter Blu-Steel
  • Start date Start date Dec 29, 2006
Blu-Steel
92
Waynesville, MO
Dec 29, 2006
  • Dec 29, 2006
Does anyone else have a squeeking headliner? I have a new 2007 GT/CS and noticed a squeek at highway speeds which seemed to come from the dash, but as I squirmed around trying to pinpoint it I realized it was coming from the headliner. When I press up on the headliner I can cause it to make the same squeek. I had the same noise with my 2003 Mach 1 but was never able to pinpoint it. If anyone has had the same problem were you able to get it fixed. I searched the threads but could not find any postings on this subject.
Thanks
mustangmike6996
5 Year Member
Nov 10, 2005
483
clinton twp, MI
Dec 30, 2006
  • Dec 30, 2006
i have this horrible rattle from my dash/A-pillars over bumps.... if you cram foam in between the a pillar and the dash it squeeks on the windshield or something close to it... and if you cram foam between the windshield and apillar it rattles against the dash...plus in the middle of my door panles (driver and passanger) about 3 inches below the window or so .. i am devloping a new rattle... its never ending...
do these sound like any possibilities? and if you find a correction for yours please post your fix!!!!
kooldawg6
mine works really well and can take a fair amount
Aug 31, 2006
1,679
Central VA
Dec 30, 2006
  • Dec 30, 2006
http://forums.stangnet.com/showthread.php?t=674661&highlight=door+rattles
Try here to see if this is what is causing your door panel rattle...I found that the panels behind the door handles rattled in mine.
Marine One
276
North Topsail Beach, NC
Dec 31, 2006
  • Dec 31, 2006
Yep, I did that after you posted it and it fixed both of my doors. Funny thing was that the rattle didn't appear to originate from that area on either of the doors. Let me know when you figure out a fix for the rattle around my Shaker 500, kooldawg!
Blu-Steel
92
Waynesville, MO
Jan 3, 2007
  • Jan 3, 2007
Nope, mine definately isn't coming from the doors or A-pillar; it's the headliner. It's a squeeking noise that sounds like vinyl rubbing against something. If you press up on the headliner hard enough you can duplicate the exact sound. The nearest I can figure is that the slightest body flex causes the headliner to rub or vibrate and cause the squeek. I only notice it when the stereo is off and I'm cruising at highway speeds. I hate to take it to a dealer and have them tear it apart and put it back together again. In my experience whenever a dealer takes components apart squeeks either get worse or new ones crop up. I guess I'll have to just keep the radio on at all times.
kooldawg6
Aug 31, 2006
1,679
Central VA
Jan 3, 2007
  • Jan 3, 2007
My Shaker 1000 has never had any issues...yet. My sugesstion would be to swap a 1000 in for your 500...
I may have to look into fixing that glovebox door rattle!!!!! My buddy and I rode up to MD last week with the radio off for the most part, but had to turn it on since that rattle got damned annoying after an hour.
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Sunday at 3:55 AM
manicmechanic007
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
