Squeeling noise in the clutch
fuzz
46
Arlington, VA
When I push in the clutch sometimes I get a squeeling noise. The noise will continue if I keep the pedal down. The noise stops when I release the pedal. It's done that about 3 or 4 times since I got it last July. Any ideas? Not sure if it's a problem or what.
TOB, take it to ford after checking for a possible tsb about it and print it out to give you a little foundation if they attempt to deny it. I had the same issue with my 99 Gt when she was a year old, they replaced the entire clutch assembly for the bubble. Good luck. :nice:
TOB After 6 Months
I had about 3,000 miles on my 2002 Saleen when the TOB started to chirp. Ford did all the work (under warranty) and haven't had a problem since. ( I have about 17,000 on the car now). Good luck!
The Bee
2002 S-281 #382 True Blue / Tan vert.
2004 DSG Mach-1
man thers a new thread like this everyday....just do the white lithium grease trick...it will only come back if you let hacks replace it... "anti hack work" supporter
